Page 1 of 2
Fuel pumps??
Posted: Tue Jun 05, 2007 9:01 pm
by musty1
Can anybody give any advise on goog fuel pumps I'm trying to go for alot of Hp so I was told to use two smaller pumps then one big pump any suggestions I'm going to be using 630cc injectors and 4 or 5 bar regulator?
cheers
RE: Fuel pumps??
Posted: Tue Jun 05, 2007 9:12 pm
by Nige_RS4
The Bosch Motorsport pump is the one to go for, although the Walbro 255 is only £90 but needs modifying to fit.
RE: Fuel pumps??
Posted: Tue Jun 05, 2007 10:32 pm
by musty1
would I be able to run two of these? or do you know what bhp it supports?
RE: Fuel pumps??
Posted: Tue Jun 05, 2007 10:56 pm
by Nige_RS4
The std RS4 pump is good for 500bhp, and the Bosch Motorsport pumps at least twice the flow of the RS4 one, so I don't think you will be needing two of those puppies!
BTW, the B5 RS4 pump only flows 5litres per hour (roughly 5%) more than the S4 pump, so there is no real point in upgrading to an RS4 pump.
RE: Fuel pumps??
Posted: Tue Jun 05, 2007 11:03 pm
by musty1
No you right wont need two if the flow rate is twice of a RS4 and it fits on the cradle (S4)?
RE: Fuel pumps??
Posted: Wed Jun 06, 2007 7:07 am
by tdiquattro
Any body got the Bosch part number / description for the high flow pump? is it the black one?
N :)
RE: Fuel pumps??
Posted: Wed Jun 06, 2007 9:21 am
by musty1
I think it is bosch 044 motorsport pump
RE: Fuel pumps??
Posted: Mon Jun 11, 2007 7:29 pm
by duncanhancox
it is the 044 - i just bought a new one from ebay for £150 delivered
RE: Fuel pumps??
Posted: Tue Jun 12, 2007 8:13 am
by tdiquattro
Thanks chaps, does the 044 pump fit straight in to the S4 pump holder,is it the same size as the original, and does the original flat round filter fit on the bottom?
cheers
Nigel
RE: Fuel pumps??
Posted: Wed Jun 13, 2007 10:49 pm
by musty1
I know it fits but with few minor changes (but don't know what hte changes are)
cheers
RE: Fuel pumps??
Posted: Thu Jun 14, 2007 11:01 am
by JonnyX
See 034motorsports site for what it looks like. You need the basket and strainer from an audi v8:
895 201 531 A
895 201 779 H
034 sold me the hardware kit (Porsche top nut, bayonet fitting etc. for ~$30)
Haven't fitted it yet though.
Re: RE: Fuel pumps??
Posted: Fri Jul 27, 2007 6:31 pm
by Chubby
[quote="Nige_RS4"]The std RS4 pump is good for 500bhp, and the Bosch Motorsport pumps at least twice the flow of the RS4 one, so I don't think you will be needing two of those puppies!
[quote]
Would advise against two fuel pumps - reason being if you have one pump and it fails the engine stops - if you have two and one fails at high speed, you still get fuel but not enough and the engine runs too lean with possible big problems...
Stick to one good one..
R.
Posted: Fri Jul 27, 2007 7:08 pm
by Chubby
duncanhancox wrote:it is the 044 - i just bought a new one from ebay for £150 delivered
This one isn't black - it's silver oram I looking at the wrong 044 pump...
Or have I had too much :drink:
R. :redrs4:
RE: Re: RE: Fuel pumps??
Posted: Mon Sep 17, 2007 11:07 pm
by tdiquattro
Ok I have the 044 pump and v8 cradle and filter. (and the pump is silver!)
Has anyone actually fitted one of these, can you tell me how the pump goes into the cradle as it has a small filter on the top edge that gets in the way.
I have emailed 034 for a price on the top banjo and bayonet fitting.
Any help would be great :)
Posted: Tue Sep 18, 2007 5:30 pm
by musty1
Thinkaotomotive will do all the fittings I used the Audi 200 cradle had to take a bit of the top of the cradle and dremal the in side to to get it to fit right.
