Vibration under braking.......
Posted: Thu Mar 29, 2007 12:19 pm
by quattrosteph
I've been on track recently and did make sure i cool down the brakes at the end of each session.
I now have some vibrations under braking at little speed when the brakes are cold, no vibrations when they are hot
Did check the pads and they are cracked in the middle, all of them (RS6 brakes) Will replace them with new ones to see. Are cracked pads can cause vibrations ??
Did check the discs and they look fine, not warp.
RE: Vibration under braking.......
Posted: Mon Apr 02, 2007 10:52 pm
by buzzard
yo quattrosteph
looked well on the track mate
you could have warped a disc , it doesn't take much.
you would need to check the disc run out with a dial gauge to check how bad this is.(most engineers could fix you up with one)
if it is now there constantly on cold i dont think there is much chance of it going.
my discs vibrate and go blue in places after a good hard drive but go ok again after a few days.
hope it goes away
Vibrations....
Posted: Thu Apr 05, 2007 11:05 pm
by quattrosteph
Warped disc........BALLS!!!!!!!!!!!!!!!!
RE: Vibrations....
Posted: Fri Apr 06, 2007 9:03 am
by derdle
If it's only slightly warped....is there a possibility that it could be skimmed at a machine shop?
Paul
Re: Vibrations....
Posted: Fri Apr 06, 2007 9:06 am
by dace
quattrosteph wrote:Warped disc........BALLS!!!!!!!!!!!!!!!!
Oh dear.......that's the danger of track days
Vibrations....
Posted: Tue Apr 10, 2007 7:50 pm
by quattrosteph
Yeh but brakes had only 2000 miles......If fitted on RS6 they should be up the job on an RS4 B5 isn't it ??? Brand new set and after a trackday (in novice
) discs are fucked ??????? I don't think it is right !!
RE: Vibrations....
Posted: Tue Apr 10, 2007 11:34 pm
by flashyg
Turn of tc/esp, as this will be applying the brakes all the time if you are chucking the car about.
RE: Vibrations....
Posted: Wed Apr 11, 2007 8:44 am
by jeffw
More likely to be either pad deposits or the pads themselves. If the discs are warped you would find it gets worse when it is hot.....If the pads are cracked you may well get the vibration your experiencing
Posted: Wed Apr 11, 2007 4:20 pm
by Marlon
I agree with Jeff, definatley pad material deposited and bonded to the disks.
Couple of high speed braking runs required to try and clear it from the disks.
