Change Pads on RS6 Callipers
Posted: Mon Jan 22, 2007 12:34 pm
by viperbl
Guys,
Do I need a tool to push back the callipers when I change these pads or is this only really for the rear ones???
RE: Change Pads on RS6 Callipers
Posted: Mon Jan 22, 2007 12:39 pm
by shineydave
fronts just push back, rears only need the special tool to set the handbrake
Re: RE: Change Pads on RS6 Callipers
Posted: Mon Jan 22, 2007 12:41 pm
by viperbl
shineydave wrote:fronts just push back, rears only need the special tool to set the handbrake
Cheers fella :)
RE: Re: RE: Change Pads on RS6 Callipers
Posted: Mon Jan 22, 2007 12:44 pm
by shineydave
np. it's a bit of a pain because there's so many pistons, as you push one back the others pop out, might be worth leaving the old pads in and levering them apart with a screwdriver or lever of some kind, don't forget to release the brake reservoir cap first and make sure you don't push the fluid level up so far it spils out
Re: RE: Re: RE: Change Pads on RS6 Callipers
Posted: Mon Jan 22, 2007 12:48 pm
by viperbl
shineydave wrote:np. it's a bit of a pain because there's so many pistons, as you push one back the others pop out, might be worth leaving the old pads in and levering them apart with a screwdriver or lever of some kind, don't forget to release the brake reservoir cap first and make sure you don't push the fluid level up so far it spils out
Got you, good idea ... thanks.
Its those little tips that stop it becoming a 2 hours job i'll bet! :)
RE: Re: RE: Re: RE: Change Pads on RS6 Callipers
Posted: Mon Jan 22, 2007 12:52 pm
by shineydave
20 mins a side with a bit of luck, if the snow holds off
