Any Ideas
Posted: Wed Mar 05, 2003 8:03 pm
by LittleSkull
My car seems to loose boost when i accelerate hard, but only in second gear. This happens once in awhile and not always. My question is....why only in second gear? Thanks
Re: Any Ideas
Posted: Wed Mar 05, 2003 8:20 pm
by Bushy
several possible problems here, which I am also acceleratiing but not just in second gear
have you checked ECU error codes?
I have found my car is mis firing on cylinder 1
Possible causes are
1 - faulty coil pack
2 - split hose
3 - sticking DV
also a possible cause is that the knock sensor is near to cylinder1, so if the engine mount is worn or flexing too much it may cause the knock sensor to pick up faulty ignition and put the engine in safe mode
It is in at the dealer next week so maybe we can find out
Re: Any Ideas
Posted: Thu Mar 06, 2003 10:28 am
by LittleSkull
Thanks Bushy. Next week i will try to go to the mecchanic and check everything out.
Cheers,
Cris
