Merc wheels on a B5 S4?
Posted: Sat Sep 16, 2006 10:50 am
by Si4
Would you put merc alloys on a B5 S4.. everything is right except the bore which is 66ish vs 57 on the audi?
cheers
RE: Merc wheels on a B5 S4?
Posted: Sat Sep 16, 2006 10:54 am
by MarkB
You need to get a ring to take up the differnece and I beleave you may need to do something with the bolt holes. I think the merc uses smaller bolts
Posted: Sat Sep 16, 2006 11:16 am
by Si4
cheers.. if it was just the bore i'd have gone for it..
Posted: Sat Sep 16, 2006 11:19 am
by MarkB
I think some people on the B5 Passat site have done it. Might be worth google'ing it...
Posted: Sat Sep 16, 2006 11:26 am
by GrahamS4
I've seen AMG wheels on a S4 Avant on the web somewhere.........
Looked quite good.
I sold my spare AMG's before I sold my C-Class. I'm sure the rears would have been too wide though.
Posted: Sun Sep 17, 2006 10:10 am
by philipwalker
The pcd is (stud patten) is the correct 5x112, however the center bore of the wheel is a fair bit bigger. So you will need to reduce the size to 57mm.
The offset could be an issue some of the big mercs run low offset say et20. This will stick out too far on say the S4.
