Page 1 of 2
k04/rs6 hybrids airflow character
Posted: Sat Jul 08, 2006 5:26 pm
by dummi
Mihnea has already convinced me these are the way forward with their high flow i'm just looking for specifics on airflow
i'm going to use rs4 heads, hopefully tubular manifolds, but probably standard 2001.5 IM, budget is killing the mods ! so what kind of flow can they give 3000-8000rpm+ when do they run out of puff...
thanks
Re: k04/rs6 hybrids airflow character
Posted: Sat Jul 08, 2006 6:58 pm
by dazzer
dummi wrote: when do they run out of puff...
thanks
Long after your licence......
Posted: Sat Jul 08, 2006 8:24 pm
by Paulm
dummi wrote:so what kind of flow can they give 3000-8000rpm+ when do they run out of puff...
thanks
Need to get a compressor map to work that out
RE: Re: k04/rs6 hybrids airflow character
Posted: Sat Jul 08, 2006 9:06 pm
by dummi
and here they are.. just need to learn how they work now so i can read them
http://forums.audiworld.com/s4/msgs/1835636.phtml
Posted: Sat Jul 08, 2006 9:43 pm
by dummi
after much studying (not really)... at 70% volumetric efficiency the compressor map is further to the right .175 for rs6k04, .158 for rs4k04 ... how the volume exactly converts into rpm in numbers i don't know.. i don't really know what i said there making this is a topic that needs further research
Posted: Sun Jul 09, 2006 8:27 pm
by Paulm
That turbo can make 1.4 bar all the way to 7k and still stay @ around 73% efficiency.
1.4 bar is all it is good for really but it can flow loads of air.
It flows more than the K16 bottom end but slightly less the the straight RS4
Sorry not got the time to work out revs etc as I am at work I will though when I get home unless someone else does it.
Posted: Mon Jul 10, 2006 2:52 am
by dummi
thanks Paul thats plenty to be going on with
Posted: Mon Jul 10, 2006 10:24 pm
by Paulm
Ok here you go.
this is just on paper remember turbos can act differently in real life but it gives you a pretty good representation of what it will do
Dots 1 to 12
1= 1bar @ 2800rpm
2= 1.1bar @ 3000rpm
3= 1.2bar @ 3200rpm
4= 1.4bar @ 3500rpm
5= 1.4bar @ 4000rpm
6= 1.4bar @ 4500rpm
7= 1.4bar @ 5000rpm
8= 1.4bar @ 5500rpm
9= 1.4bar @ 6000rpm
10=1.4bar@ 6500rpm
11=1.4bar@ 7000rpm
12=1.4bar@ 7500rpm
Posted: Mon Jul 10, 2006 10:52 pm
by DavidT
What top end mods will you do to allow you to rev to 8k ?
Posted: Tue Jul 11, 2006 3:00 am
by dummi
top end? do you mean bottom end? lightened crank , uprated rods. should be able to get more than 8k out of it... HTH?
Posted: Tue Jul 11, 2006 8:44 am
by tartan_rob
Those spool up figures look about spot on and in-line with what I'm getting but they can provide loads more boost than that, Mihnea was going to have mine peaking at 1.7 I think with 1.5 at redline. I am still running std cats but they should spool up quicker once they have been changed for 100cell jobs...
Posted: Tue Jul 11, 2006 9:39 am
by JonnyX
dummi wrote:top end? do you mean bottom end? lightened crank , uprated rods. should be able to get more than 8k out of it... HTH?
I think you will need to do something with the valvetrain as
well to get to 8K+
Posted: Tue Jul 11, 2006 10:19 am
by dummi
@paul thanks theres plenty there then
@jonnyx yeah i've been looking at mechanical lifters, its just out of my budget right now, more likely next year. topend is heads rs4 with rs4 cams, revolver do some street cams and more aggressive race cams i'll be looking at..
Posted: Tue Jul 11, 2006 11:19 am
by Paulm
Yeah I am sure you could run more than 1.4bar but I just plotted a graph relevant to the compressor map you see.
1.4bar @8k would be a flying machine
Posted: Tue Jul 11, 2006 12:47 pm
by tartan_rob
FYI...I think you'll find the NA heads from the 2.8 flow approx 30% more air.....
