Page 1 of 2
K03-04 Hybrids?
Posted: Wed May 31, 2006 2:38 pm
by Paulm
Any1 ever though of going down this route.
That way you would keep the excellent low down grunt of the S4 but would get better top end like the RS4.
Not sure if it can be done or what sort of max power they would produce.
I remember driving Harry's MTM'd RS4 it had loads and loads of power but took a wee bit to get going, where as my MRC'd S4 was instant but had no where near as much top end power. If we could have both it would make for a very fast car.
RE: K03-04 Hybrids?
Posted: Wed May 31, 2006 2:48 pm
by S2tuner
It has been done, Paul, but the outcome wasn't very positive, too high back pressure from the wee K03 hot sides and not enough top end power could be achieved. This along with some reliability issues from what I've heard too...
IMHO not a great idea. straight K04s on an S4 aren't that laggy and low RPM grunt is better than an RS4 due to the different head port design on the S4.
HTH,
Mihnea
RE: K03-04 Hybrids?
Posted: Wed May 31, 2006 3:30 pm
by andy1234
however, if you want a pair of K03s for experimental purposes your more then welcome to them. You still got them Minhea :lol:
Posted: Wed May 31, 2006 4:53 pm
by Paulm
Cheers Mihnea that does help. So I will scrap that idea. Good to know the S4 will build boost a wee bit quicker than the RS4.
Thanks for your offer Andy but I have no idea what I would do with them apart from prob take them to bits just to play :lol:
Posted: Wed May 31, 2006 5:15 pm
by DavidT
K04's are hardly any different to K03's low down in my experience :thumbs:
Posted: Wed May 31, 2006 5:18 pm
by harry
so its all in the head port design as Minhea said. Ok but what does that mean in laymans terms?
Posted: Wed May 31, 2006 6:02 pm
by Paulm
It means you better watch out Harry :thumb: :rocker:
Not sure but prob the RS4 head will have bigger more free flowing ports to aid the amount of flow higher up the rev range, but the bigger the ports the slower the gasses will travel so will hurt spool up slightly. This is only a small prob low down the rev range.
I think Volume and Velocity both have a bearing on turbo spool time and it seems to be a bit of a compromise.
Smaller ports = fast flowing air but restrictive @ high revs
Larger ports = slower air but more of it for making bigger power.
Once the turbos spool up bigger ports all the way.
Well thats my understanding anyway :wink:
Posted: Wed May 31, 2006 6:25 pm
by s4woody
so does that mean having 2.4 cylinder heads gives you even better flow through the valves making more power or is it just beacuse they have bigger valves being from a N.A engine...
Posted: Wed May 31, 2006 10:01 pm
by harry
:oops: :roll: :wink: :cry: :oops: :twisted: :x :lol: :? 8) :o :D :shock:
Posted: Wed May 31, 2006 10:32 pm
by Paulm
Ok maybe not :lol: :smile_smoking: :thumbs:
Good to know Dave.
Sorry Woody I have no idea re the 2.4 heads :?
Posted: Mon Jun 05, 2006 1:19 pm
by Dippy
Take a look at the torque curve of a K04'd S4 and compare to a remapped K03 S4 and you'll see that the extra lag is almost negligible.
Posted: Mon Jun 05, 2006 2:56 pm
by duncanhancox
unfortunately the torque curve doesnt really tell you anything about lag - only lack of boost at lower revs
the dyno run is done with the throttle wide open all the time and allows the revs to build up - real lag shows up when you press the throttle and it takes time for the torque/boost to arrive - this doesnt show at all on the torque curve, but a larger turbo will have less low down torque and probably more lag so the 2 are often associated together with larger turbos
Posted: Mon Jun 05, 2006 2:58 pm
by duncanhancox
Posted: Fri Jul 07, 2006 7:45 pm
by BlackS3
How about an IHI turbo kit??
More power and torque with a good remap. Jabbasport are doing quite well with that set up. K04's are quite a small turbo to be dealing with a lot of exhaust gases.
Just a thought as I am having a 1.9 rebuild to my S3 but power/torque will be severely limited till I can afford to put the IHI kit on (like 100bhp). Also the IHI turbo tends to be quite reliable. :wink:
Posted: Sat Jul 08, 2006 12:53 am
by dummi
@black s3 this is for the 2.7t, ihi don't offer a solution afaik
@s4woody, i think valves are same size but ports are larger on 2.4 , no?
