EGT and Air Fuel Ratio Gauges
Paulm
Post by Paulm » Sun Mar 19, 2006 1:36 pm
Anyone ever fitted these gauges?
I was thinking of putting 4 on my front pillar. 2 x AFR off the lambdas (narrow band I know but better then nothing) and 2 x EGT off the probes on the car.
any thoughts appreciated
cheers
Paul
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
dummi
RE: EGT and Air Fuel Ratio Gauges
Post by dummi » Sun Mar 19, 2006 1:43 pm
why 2? if there was a difference on each side of the engine wouldn't it be quite obvious rather than a balanced change across the engine
Paulm
Post by Paulm » Sun Mar 19, 2006 1:52 pm
Each bank is independent of each other. If one is running lean due to say a blocked injector you would see the AFR lean off and the EGT rise but only on one bank.
I intend to just link into what is already on the car. which is 2 lambdas and 2 EGTs
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
confusionhunter
Post by confusionhunter » Sun Mar 19, 2006 2:38 pm
ive done that but not on an S4.... not sure you can link ingto the existing EGT sensors, but if you can let me know how!!!
Mark.
dummi
Post by dummi » Sun Mar 19, 2006 3:50 pm
more details on the EGT sensors and guage please , i've seen the 4 lambda's where are the stock EGT's?
S2tuner
Trader (Expired)
Post by S2tuner » Sun Mar 19, 2006 4:38 pm
I don't think you can read the stock EGT sensors, they put out a PWM 0-5v signal that ranges from 945 to 1035 degrees C. The issue could be the impedance of the display you'll be using and whether it will affect what the ECU reads off the sensors or not...
I'll be installing K-Type thermocouples in each downpipe in my own car, they don't cost too much and aren't that hard to install... I've been using for over 3 years this guy's (http://www.smods.de.vu) EGT gauges and thermocouples for mapping purposes, they've always worked a treat and nothing ever went wrong with them. Now I have no idea where I'll install the displays in my car, I don't want it too look like it came out of the fast and the furious, yet I want to have dual WBO2/EGT/pre-post IC boost and intake temp gauges on it.... maybe a separate display that can fold into the glove box???
HTH,
Mihnea
dummi
Post by dummi » Sun Mar 19, 2006 5:06 pm
S2tuner wrote:. Now I have no idea where I'll install the displays in my car, I don't want it too look like it came out of the fast and the furious, yet I want to have dual WBO2/EGT/pre-post IC boost and intake temp gauges on it.... maybe a separate display that can fold into the glove box???
yeah same problem! if they are thin lcd type guages how about putting them in your sunvisor , i've done that with my sat nav and haven't had any regrets in 2 years much easier than having them in some far obscure place when you want them
good links just reading through with google language, Mihnea i will be bringing my car to you at some point i will have time to put it back together in april should be good to go after then
dummi
Post by dummi » Sun Mar 19, 2006 5:27 pm
looks like the SMOD would need just a tap n die to for the 8mm x 1mm thread , simply screw bung into tap and wire up to display is that right?
how easy is the display to read? does it give relative voltages through different materials that are easy to translate?
if its that easy i will put my order down for one
Paulm
Post by Paulm » Sun Mar 19, 2006 5:33 pm
Yeah that does help Mihnea. I was hoping some one would know about the EGTs as i had no idea if i could link into them or not. Oh well another wee job turning into something bigger 8)
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
S2tuner
Trader (Expired)
Post by S2tuner » Sun Mar 19, 2006 6:25 pm
@dummi: the SMOD displays the temperature in degrees C. The display isn't very thin, probably 20-30mm if memory serves (the 2 ones that I have are bolted into a display box that I use for tuning so can't get them out just now)...
HTH,
Mihnea
PS: ideally you need 2x thermocouples and 2x type D SMODS on a 2.7T so you can check the temperature on each bank separately. I'd put them in the downpipe flanges so you don't run the risk of the sensor melting and going through the turbine if you put it in the exhaust manifold...
dummi
Post by dummi » Sun Mar 19, 2006 8:52 pm
thanks Mihnea , easy enough to read then , will give it a shot, i'm thinking about making a panel between the driver and centre console to hold them :thumbsup:
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Mar 20, 2006 9:56 am
have fitted a wide band air/fuel gauge to my S4 now. excellent bit of kit. you only need one gauge. tapped it into the exhaust before the main box.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Users browsing this forum: No registered users and 65 guests
