Auto Door Lock
Posted: Sun Feb 01, 2004 11:52 pm
by david7m
A friend who is a ADT changed my car yesterday so when I get to 10 mph it locks the doors. It does this when you first pull off, but if I stop, let a passenger out, then pull away (without stopping engine in between), is the door supposed to re-lock? Because it doesn't ! My door doesn't re-lock either.
Re: Auto Door Lock
Posted: Mon Feb 02, 2004 12:03 am
by JAMES
mines the same at about 5 mph and also does not re lock [img]images/graemlins/033102bad_1_prv.gif[/img]
Re: Auto Door Lock
Posted: Mon Feb 02, 2004 12:11 am
by david7m
I was almost sure the Golf used to lock [img]images/graemlins/confused.gif[/img]
Also, does having this feature on invalidate the Thatcham Insurance approval? I had an Escort GTi with a Clifford Concept 50 alarm. It said in the hand book, that if I activate the 'Blackjacks' (need a code etc. if door is opened then you pull away, it would run for a minute then stop without code) that this removes the approval and is no longer valid !?!?!?!?!!?!?!!??!!?!
Re: Auto Door Lock
Posted: Mon Feb 02, 2004 7:10 am
by Carps
The later B6 chassis will relock. My B5 (2000my) won't.
I guess this is something Audi changed...
Re: Auto Door Lock
Posted: Mon Feb 02, 2004 11:27 am
by DuncS3
My S3 doesnt relock
Dunc [img]images/graemlins/s3addict.gif[/img]
Re: Auto Door Lock
Posted: Tue Feb 03, 2004 1:32 pm
by Dippy
Officially it's 15mph, which is what mine seems to be. It only does it the first time, so your operation is correct.
Re: Auto Door Lock
Posted: Tue Feb 03, 2004 6:43 pm
by kiwi_mtm
Mine is the same.
Also..
One unlock press on the remote, ONLY unlocks the drivers door. Two, and then all Doors.
Re: Auto Door Lock
Posted: Tue Feb 03, 2004 9:18 pm
by david7m
One press on mine opens the two front (S3 [img]images/graemlins/grin.gif[/img]) and the boot.
I wonder if its a setting you can change?
I'm sure my friends Golf locks again when you move, but it is a bit newer than mine!
Re: Auto Door Lock
Posted: Tue Feb 03, 2004 9:46 pm
by Carps
You can change all that stuff - ask a friendly dealer or find someone with VAG-COM...
