Page 1 of 2
Upgrading to 19" rims
Posted: Fri Jan 31, 2003 11:39 am
by Bushy
So I think i am going to go for this
I will have a set of Sportec and a set of the 5 spok RS6 ones
However the question I have is who is using what tyre on this rim?
I have always tried to maintain the 94Y rating Audi specified but can only find the following tyres, with my short search on the web, which are 30 profile
Also i am concerned as to which tyre will fet both rims as the Sportec rim looks a bit different to the RS6 rim
Any ideas anyone
List a follows
Yokohama AVS 265 19 93Y
Yokohama AVS 275 19 96Y
Yokohama AVS 285 19 94Y
Bridgestone S03 265 19 93Y
Bridgestone S03 275 19 96Y
Bridgestone S03 285 19 94Y
Toyo 30 SERIES
tyre size,load/speed index, overall dia, overall width, static radius, revs per mile, rim size
265/30ZR19, 93Y, 643, 271, 305, 818, 9.5 - 10.5
275/30ZR19, 96Y 649 278 306 813 to suit rim 9.5 - 11.0
275/30ZR20 97Y 674 278 320 779 to suit rim 9.5 - 11.0
Anyone else tried anything else?
Dave what rated tyres come as standard?
Re: Upgrading to 19" rims
Posted: Fri Jan 31, 2003 1:40 pm
by TimJMS
Careful about going any wider than 265/30 R19, Bushy, Mines already damned tight up there! How do I post a picture here guys???!! [img]images/graemlins/frown.gif[/img]
Have circled the area of concern in my gallery mate.
Posted: Fri Jan 31, 2003 2:16 pm
by Bushy
[img]images/graemlins/blush.gif[/img]
it is tight
however the wider rims are the right load rating
not sure wot to do now
Posted: Fri Jan 31, 2003 2:42 pm
by PhilT
Open the gallery and display the picture you would like to attach. Right click and go to Properties. Highlight the Address (URL) should look like this '
http://gallery.rs246.com/albums/TimJMS/clearance.JPG', then when it is highlighted in blue, do CTRL+C (Copy). To insert the image in a post use the Instant UBB Code -> Image, and paste the location (CTRL+V).
Should look like this, but without the spaces:
[image]
http://gallery.rs246.com/albums/TimJMS/clearance.JPG [/image]
Posted: Fri Jan 31, 2003 3:21 pm
by Dave
Hi Steve,
My car came with 255/35/19 ZR.. not sure on the loading.. will have to look
I have the 5 spoke alloys and the tyres are Continential Contact Sports II ... the seem Ok.. good wear and grip but nothing exceptional.
dave [img]images/graemlins/biggrin3.gif[/img]
Posted: Fri Jan 31, 2003 3:24 pm
by Dave
Just been out to check the load rating:
The tyres say 96Y .. what does that mean?
Dave
Posted: Fri Jan 31, 2003 4:35 pm
by wazza
usually very expensive [img]images/graemlins/biggrin3.gif[/img]
Posted: Fri Jan 31, 2003 4:45 pm
by PhilT
Excellent [img]images/graemlins/jump.gif[/img]
Actually see
here.
Just means that you drive a lardy car - 4 x 710 = 2840 Kg!!! [img]images/graemlins/tung2.gif[/img]
Posted: Fri Jan 31, 2003 9:08 pm
by s2driver
Y is the speed rating. And 96 is the load index. There is a table that translates this into kilograms and pounds...best one was one the pirelli site (if you can find the right page). There is also another chart that shows you how the maximum speed capability of tyre varies with load increase (carrying passengers, luggage etc). You need to use a combination of the load and speed rating to determine the capability of the particular tyres carrying the mass of your car plus whatever payload you carry. I will try and dig out some data if anyone wants.
One site I have to recommend is
www.tirerack.com . They are in the States but have a massive amount of manufacturers data regarding tyres including dimensional stuff like diameters, section widths, revs per mile etc as well as test reports/surveys and treadwear/grip comparisons. Some surveys have feedback from millions of tyre miles from just one tyre type. Great place to have a browse and understand tyres.
You would also be amazed at the variation in revs per mile for a given tyre size from different manufacturers. This is important if you don't want to screw your speedo calibration. When I changed my wheels and tyres I spent some time establishing how accurate my speedo was before knowing how much the diameter could change whilst still maintaining optimistic speedo readings. Tyre manufacturer's data also allowed me to determine my own wheel offsets and tyre width/aspect ratios to avoid clashing suspension bits.
Lee
Posted: Sat Feb 01, 2003 2:03 pm
by TimJMS
PhilT - thanks for the detailed help on posting images. I am sure there are many others wondering about that as well. Still, it does seem long winded after the simplicity of RS4.org, but understand that the new way may be the best for reasons of forum speed for slow dial - up users like myself? [img]images/graemlins/confused.gif[/img] Bit fik when it comes to tech!
it is tight
Bushy if you really are that worried about having the correct load rating (and I am not overly concerned when its such a small difference, personally) Then you could try using a slightly wider spacer to go for the 275's, but then you have to start to wonder about the extra stresses being imposed on the wheel bearings under hard cornering!!!
Oh AND if the tyre is actually going to seat properly on the rim, Oh AND if the body work is then going to be sandblasted by road debris............
It aint easy! [img]images/graemlins/spineyes.gif[/img]
Posted: Sat Feb 01, 2003 3:17 pm
by Bushy
so who else has 19's other than Andy?
Posted: Sat Feb 01, 2003 9:19 pm
by Dean
Bushy if you get 30 profile tyres your gonna end up with a garage full of benders like me [img]images/graemlins/frown.gif[/img]
The roads where we live are <beep> mate [img]images/graemlins/frown.gif[/img] good luck [img]images/graemlins/icon_lol.gif[/img]
Posted: Sat Feb 01, 2003 9:27 pm
by Dean
benders [img]images/graemlins/frown.gif[/img] [img]images/rsul/3171-DSC00525.JPG[/img]
Posted: Mon Feb 03, 2003 12:53 am
by Andiroo
Sorry Bushy, been away for a few days [img]images/graemlins/laugh.gif[/img]
The SP9000 Dunlop's are 265/30/ZR19, load rating unsure I will check tomorrow - But believe it or not they are just turning 19000 careful miles [img]images/graemlins/roflmao.gif[/img] and still look as new - although they must be the worst tyre I've ever had on the car, even the Pirellis were better [img]images/graemlins/laugh.gif[/img]
Try the 265/30 Yokos mate, that's what I'm trying next, and it would be good to get your feedback [img]images/graemlins/wink.gif[/img]
Andiroo
Posted: Thu Feb 06, 2003 2:41 pm
by anakin
The RS6 9x19" have ET 35mm so you will need spacers (15mm) to reach the 20mm. Right? What spacers can be used?
I am also hesitating buying the Sportec 8.5x19" or the RS6-ones. What could you suggest?
