Exhaust
kcsun
Exhaust
Post by kcsun » Sun Jul 20, 2003 11:37 am
I have been talking to a firm about a custom exhaust. They say you do not need cats as they restrict flow (leave the legalities out)But cannot give an answer to the question - what happens to the sensors - oh just leave them disconnected sir! surely the ECU looks at these and alters settings accordingly?
Any advise would be appreciated
kc [img]images/graemlins/s4anogaro.gif[/img]
Taipan
Re: Exhaust
Post by Taipan » Sun Jul 20, 2003 12:46 pm
Ken,
I went through that, by incident, with the M Coupé and had a legal expert audit the car so maybe this can be a first hint.
I asked him if the missing cat could have damage the engine, especially since the disconnected "alpha" sensor wasn't reporting anything to the Ecu. His answer : no, the ECU returns to standard default setting so it basically means your pollution level isn't controlled anymore.
They also plugged in the computer analyzer to check and found no significant defective incidents in the memory (something like 6 months).
Now if true for a stock ECU, it maybe something to check when someone gets a Stage I ECU.
Eric
- RS4 V6 Biturbo Imola Yellow (2001)
• Custom MTM 460hp manually tuned by Peter Link on MTM dyno at Ingolstadt HQ.
• Custom Full Milltek: Sport-Cats / Mid-Silencer: suppressed / End-Silencer: reduced.
• Full Mov'It upgrade: Front 380mm - 6 pistons / Rear 220mm - 4 pistons / Parking addon.
- Joined the Dark Side (aka. Darth Elon) circa 2013.
kcsun
Re: Exhaust
Post by kcsun » Sun Jul 20, 2003 7:43 pm
Thanks Eric
I already have the MTM chip perhaps someone else knows if that sensor has any effect on the MTM chip?
Nige_RS4
Re: Exhaust
Post by Nige_RS4 » Mon Jul 21, 2003 9:38 am
I believe you will get the occasional DTC, but there are ways round this .... 1) you can supress the O2 sensor DTC via ECU s/w (however I don't think MTM do this), there are O2 dummy loads available which fool the ECU into thinking everything is OK, or finally, keep resetting the DTC with VAG-COM [img]images/graemlins/033102bad_1_prv.gif[/img]!
My advice would be to use sports-cats and keep all the sensors in place to ensure you ECU has a chance at getting the mixture right.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
kcsun
Re: Exhaust
Post by kcsun » Mon Jul 21, 2003 12:08 pm
Sorry I am thick - whats DTC? [img]images/graemlins/stupid.gif[/img] [img]images/graemlins/idea.gif[/img]
Nige_RS4
Re: Exhaust
Post by Nige_RS4 » Mon Jul 21, 2003 12:25 pm
DTC: Diagnostic Trouble Code [img]images/graemlins/thumbs.gif[/img] Your ECU (and other computers in the car) log all error codes (DTC's) - serious problems will cause the ECL: engine check light (orange light on your tacho) to come on. You will need a VAG-COM or VAG 1551 to read/reset these.
Nige.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
BRETTCOLLINS
Re: Exhaust
Post by BRETTCOLLINS » Mon Jul 21, 2003 12:30 pm
HAVE REMOVED THE CATS ON MY S4 WHEN TUBE TORQUE MADE THE EXHAUST, THEN THE CAR WAS REMAPPED BY AMD. THEY TOLD ME THAT IT WOULD BE OK AS LONG AS THE CAT WERE REMOVED B4 THERE WORK WAS DONE.
BEEN 9 MONTHS, ONLY PROBLEM THAT EPC LIGHT HAS COME ON 3 TIMES NOW.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Users browsing this forum: No registered users and 65 guests
