Vibrations under acceleration RS4 B7
TheresonlyoneBiff
Post by TheresonlyoneBiff » Fri Oct 11, 2019 6:18 pm
I threw the o/s front driveshaft a month or so back, my local garage replaced it with a driveshaft from Parker’s. Once I’d got it back I could feel some vibration under acceleration so the suggestion was to change the n/s shaft too. After that was changed the vibrations were still there. After some investigating the garage discovered that Parker’s had supplied two different shafts one from shaftec and a premium one which according to them shouldn’t have been supplied (blamed the new lad on the phone), after some phone calls Parker’s replaced the o/s shaft with a shaftec the same as the n/s shaft. All seemed well but once again under acceleration the vibrating is still there and it’s doing my stack in. Is this a case of the supplied shafts aren’t suitable and I need to get them from Audi or could it be something else? Any advice will be greatly recieved.
RS4 B7, Vossen HF2 Wheels, DKU Performance custom exhaust, H&R Coilovers, K&N Filter
Foxmeister
Re: Vibrations under acceleration RS4 B7
Post by Foxmeister » Fri Oct 18, 2019 5:43 am
Your wheels, are they correct CB? Do you use spigots? check to see if its still there
TheresonlyoneBiff
Post by TheresonlyoneBiff » Fri Oct 18, 2019 9:37 am
Brand new wheels with spigots, fitted, balanced and laser aligned. The vibrating started before I’d changed the wheels Image
TheresonlyoneBiff
Post by TheresonlyoneBiff » Sun Nov 10, 2019 11:16 pm
Update. Replaced the o/s driveshaft with an Audi shaft, cost a bomb but problem solved
