Quickest and cheapest to get to 450bhp on Std engine..?
S2tuner
Trader (Expired)
Post by S2tuner » Fri Dec 09, 2005 9:10 pm
Mine is going to go through the following stages in the next few months:
RS6 hybrids
RS6 hybrids and FMIC and bigger injectors (630cc) and fuel pump
RS6 hybrids, FMIC, fuelling, NA heads, RS4 intake manifold, tubular exhaust manifolds
Hopefully 550 should be feasible with the latest stage. Thinking about water injection too, but other tricks as well :lol:
Next step up is going to be massive turbos, and not Garretts, something no one has done before, still working on practical aspects of it but they should work and should be good for 650-700 BHP.
Might go to 3.0 liter if I go crazy and the bottom end has to be taken apart...
This will remain my daily driver for as long as possible as well. Luckily I'm doing the RS6+ brakes before hitting 400 BHP.
Mihnea
CliveH
Post by CliveH » Fri Dec 09, 2005 9:24 pm
Mihnea,
Can you explain what you mean by RS6 hybrids please?
Cheers,
Clive
S2tuner
Trader (Expired)
Post by S2tuner » Fri Dec 09, 2005 9:29 pm
Yup, K04 hot side, center bearing housing and cold side housing, with an RS6 compressor wheel. The RS6 compressor wheel is much more efficient than the standard RS4 K04 one and flows more air at higher revs....
CliveH
Post by CliveH » Fri Dec 09, 2005 9:46 pm
Thanks for that Mihnea - I'll be in touch...! :thumbs:
Clive
DavidT
Post by DavidT » Fri Dec 09, 2005 10:25 pm
S2tuner wrote:Yup, K04 hot side, center bearing housing and cold side housing, with an RS6 compressor wheel. The RS6 compressor wheel is much more efficient than the standard RS4 K04 one and flows more air at higher revs....
Is there any disadvantage with these compared to standard K04's ?
S2tuner
Trader (Expired)
Post by S2tuner » Fri Dec 09, 2005 10:57 pm
@David: other than the price, which is obviously higher, none that I can think of. Low revs spool up is as good as RS4s as far as I'm aware, but then I have never played with a set of these yet.... we'll see how they run on my car...
HTH,
Mihnea
KayGee
Post by KayGee » Sun Dec 11, 2005 12:16 am
The RS6 compressor wheel is also designed to be run on the same K04 shaft in the RS6, meaning it is a more natural fit than the K16 and K24 wheels used in other K04 hybrids. This should mean it is a balanced combination, and also not stressing the shaft, means it will probably be reliable option as well.
Mik
Post by Mik » Sun Dec 11, 2005 12:48 am
Yup reliability is key, personally I wouldnt pay that much of a premium over the K04's without assurances of similar durability. A lot of the K04/K16s have failed AFAIK and the K04/RS6s hybrid is very new.... Am also interested in FMIC, but not the DUH FMIC - be nice with something more local.
Mik
2014 Suzuka RS6
S2tuner
Trader (Expired)
Post by S2tuner » Sun Dec 11, 2005 1:10 am
There will be something local for the FMIC, trust me :p
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Jan 01, 2006 4:44 pm
FMIC is the way forward. the only thing that I need now.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Users browsing this forum: No registered users and 31 guests
