RS4 B9 video of 20mm Spacers fitted
Gio G
Re: RS4 B9 video of 20mm Spacers fitted
Post by Gio G » Fri Jul 06, 2018 12:34 pm
Manged to get 15mm on front and rear fitted on my RS5 last week. Just looks so much better... how they should have come out of the factory..
G
Brooner
Post by Brooner » Fri Jul 06, 2018 12:38 pm
Need some before and after pics
Gio G
Post by Gio G » Fri Jul 06, 2018 12:57 pm
Did not take a picture at the same angle unfortunately.. Top is with 15mm, feels out arches..
Terminator_X
Post by Terminator_X » Fri Jul 06, 2018 1:45 pm
Gio G wrote:Manged to get 15mm on front and rear fitted on my RS5 last week. Just looks so much better... how they should have come out of the factory..
G
Where did you buy them from pls?
TX.
Gio G
Post by Gio G » Fri Jul 06, 2018 3:10 pm
R-tec Auto design in St Albans. They used Bimecc spacers and new bolts, quite reasonable.
G
AJ13
Post by AJ13 » Fri Oct 12, 2018 10:46 pm
I’ve now been running 15mm front and 20mm back for months on it. 20mm was too wide on the front.
I had to remove one clip and screw from the wheel arch but it’s only a tiny one holding in the liner on the arch, and there’s tons extra. If you own anRS4 B9 10mm front and 15 back to be safe, and 15mm front and 20mm back are the biggest. Oh, and I got my spacers and bolts from venom motorsports. Top guys.
Brooner
Post by Brooner » Sat Oct 13, 2018 9:11 am
Thanks for the update on this
For those with the standard 20" this will save others the trial and error process
AJ13
Post by AJ13 » Sat Oct 13, 2018 9:36 am
Totally. Remember, 20mm spacers volt into the hub, so you use existing bolts, 15mm spacers you have to use long bolts that go through the wheel and spacer into the hub, so you need approx 15mm longer bolts. You may also want to buy 2 new longer locking wheel nuts, as your old ones on the front won’t work. And don’t forget to removed the horrible screw and clip in the front wheel arches.... it’s only design purpose can be to rub against tyres!
Users browsing this forum: No registered users and 6 guests
