Excellent write-up on a mod for the S4 after-run pump
Been looking for this for ages now - seems like someone's already done it. This mod basically replaces the sensor switch that operates the pump which circulates water around the turbo casing after the engine is switched off. You won't nornally hear this operating unless you track your car. This is basically on OEM turbo timer - gotta be a must do mod for any S4.
http://forums.audiworld.com/s4/msgs/1629709.phtml
Nige
Nige
Yes - I did this for my car ages ago. I even posted the details on this site...
2001 Silver S4 Avant
http://www.rs246.com/modules.php?op=mod ... ic&t=27175
http://www.rs246.com/modules.php?op=mod ... ic&t=18058
http://www.rs246.com/modules.php?op=mod ... pic&t=6734
correct me if i'm wrong Dippy, but your method involves cutting wires and using other bits whereas Nige's solution involves just replacing the actual sensor with one which switches the pump on at a lower water temp. Seems logical to me - anyone tried this yet??
which method is best or do they both achieve the same results but one with more effort?
great write-up on a mod for the S4 after-run pump -RS4's too
This alternative temperature switch was fitted to my RS4 this weekend - it works a treat and certainly helps to cool the oil temp quicker too. The pump and radiator fan do indeed activate after turning off the engine, but I've noticed the following:
1. After normal (pottering around town) type driving, there is about a minutes delay before the pump and fan starts up after turning off the ignition. I presume that the underbonnet temps have then risen sufficiently which then causes the new switch to activate.
2. If the car has had a good blast beforehand, then it comes on straight away after turning off the ignition.
Thanks for digging out the info Nige.
