Water Injection..... Cooling
johneroberts
Post by johneroberts » Wed Jan 29, 2003 10:40 pm
Water Injection systems Are somthing a few people are connsidering...Perhaps it would be interesting to discuss there benefits... AS some people may not understand.
jr
Driving is believing
RS246 Founder
Andiroo
Re: Water Injection..... Cooling
Post by Andiroo » Wed Jan 29, 2003 11:05 pm
The current leaders in water injection are these guys
Aquamist
It comes in three forms;
Charge cooling on an air to air intercooler, where atomised water sprays are used after the intercooler but well before the inlet plenum. This cools the charge into the combustion chamber and reduces detonation/helps combustion efficiency. Ignition and ECU parameters are not affected in any way whatsoever.
Charge cooling as above, but before the intercooler - usually only advised for racing purposes and not advised for road use.
Direct water injection, where atomised water spray is misted into the inlet plenum (or direct port) to dramatically reduce detonation and improve combustion efficiency. This is ideally suited to very humid climates (like Florida) but unfortunately the ECU has to be mapped for it, and if you run out of water - oops [img]images/graemlins/shocked.gif[/img] Not particularly recommended for the UK.
There are also external intercooler sprays, which do work, but unfortunately are triggered after the intercooler is hot and are therefore a 15 second waste of time [img]images/graemlins/tongue.gif[/img]
The first option is the best for a modded UK car, triggered by a mappable ECU with three inputs. Intercooler housing temp, intercooler air temp (after the intercooler), and turbo boost combine to give the "Fang" factor which is a prediction in time of when the engine needs a cool charge - basically means you aren't sat at the lights with a hot intercooler and no boost, with water pissing into your combustion chamber [img]images/graemlins/grin.gif[/img]
Inlet temperature drops of at least 16c can be had using this correctly, which when linked to maximum boost heat generation of a modified engine, can mean improved air/fuel combustion of up to 20% [img]images/graemlins/shocked.gif[/img] The bhp/torque increase depends on the type of engine and how much boost you're running, but hey, it must be worth something.
I'm finding out during the course of next month exactly how much it will give. Wish me luck [img]images/graemlins/cool.gif[/img]
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
Bushy
Post by Bushy » Thu Jan 30, 2003 10:46 am
Good luck [img]images/graemlins/thumb.gif[/img]
Can't beat a bit of boost!
dog
Post by dog » Mon Feb 17, 2003 7:58 am
How is it going?
Andiroo
Post by Andiroo » Mon Feb 17, 2003 8:48 am
Should find out next week mate [img]images/graemlins/wink.gif[/img]
Andiroo
dog
Post by dog » Wed Feb 19, 2003 8:09 am
Let me know!
Users browsing this forum: No registered users and 9 guests
