REVO SPS-3 device for VAG-Com
Taipan
Post by Taipan » Mon Oct 13, 2003 5:02 pm
Hello,
I saw in the Tuning Quick Reference Guide for the SPS-3 that :
"it is important to mention that Vag-Com -from RossTech- can be used along with your SPS-3 device to 'dial' the settings your car like best"
Has anyone done this ?
If so, what kind of cable did you use to connect the SPS-3 to your notebook serial or USB port ?
(the SPS jack look like a proprietary port)
Cheers,
Eric
- RS4 V6 Biturbo Imola Yellow (2001)
• Custom MTM 460hp manually tuned by Peter Link on MTM dyno at Ingolstadt HQ.
• Custom Full Milltek: Sport-Cats / Mid-Silencer: suppressed / End-Silencer: reduced.
• Full Mov'It upgrade: Front 380mm - 6 pistons / Rear 220mm - 4 pistons / Parking addon.
- Joined the Dark Side (aka. Darth Elon) circa 2013.
PhilT
RS246.com
Re: REVO SPS-3 device for VAG-Com
Post by PhilT » Mon Oct 13, 2003 5:11 pm
Apple MAC to PC serial cable.
Taipan
Post by Taipan » Mon Oct 13, 2003 5:41 pm
Thanks Phil !
So that would be more precisely :
a Apple Din8 to PC Serial D9 Female Cable
Is that the one ?
Eric
PhilT
RS246.com
Post by PhilT » Mon Oct 13, 2003 6:03 pm
[img]images/graemlins/thumbs.gif[/img]
Nige_RS4
Post by Nige_RS4 » Tue Oct 14, 2003 9:30 am
What advantage would connecting the SPS-3 to VAG-COM give you [img]images/graemlins/confused.gif[/img]
Nige.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
PhilT
RS246.com
Post by PhilT » Tue Oct 14, 2003 9:46 am
You don't have to buy the vag-com lead.....
DavidT
Post by DavidT » Tue Oct 14, 2003 11:07 am
So SPS3 + Apple Din8 to PC Serial D9 Female Cable + Ross-tech VAG-COM software = fully functioning system.
Where could one purchase the apple lead ?
And can the system be used with a non-Revo'd car ?
Thanks in advance.
Taipan
Post by Taipan » Tue Oct 14, 2003 12:41 pm
Just a light warning before you buy the full VAG-Com software at USD 99 and the Mac-PC serial cable.
Try the free limited version of the Vag-Com and install it on your notebook.
Then bring that and the SPS-3 switch to the computer store to test their Mac-PC serial cable before buying.
I just did that and it didn't work (ie. the SPS-3 switch didn't get recognized by the Vag-Com, just an "unknown device").
The cable dealer thought it might be because, although it's using a Din8 and a D9 plugs, the connections inside might be different and the cable would probably need to be bought from Revo direct.
A lesser issue was the shape of his Din8 plug case that was bulky and square and couldn't fit in at first into the SPS switch (need a thin and round plug).
Eric
Paul-RS
Post by Paul-RS » Tue Oct 14, 2003 3:21 pm
not sure where Revo source theirs, but i know they cut the insulation back for it to fit into the sps device and make a connection.
try that Eric, but obviously means buying a lead to cut....
Robert
Post by Robert » Tue Oct 14, 2003 4:10 pm
you also have to turn both switches to 0 to allow it to work. Works fine with my SPS1 also tried it with an SPS3 and worked.
Jonah
Paul-RS
Post by Paul-RS » Tue Oct 14, 2003 4:28 pm
where you source your lead jonah?
I forgot to mention the 0 - 0 setting!
DuncS3
Post by DuncS3 » Tue Oct 14, 2003 4:58 pm
Eric
I bought an apple to pc lead also, and I couldnt get it to work with the SPS-3.
Dunc
Robert
Post by Robert » Tue Oct 14, 2003 5:28 pm
Twisted Revo's arm and they gave me one. I know someone who got the mac cable and that didn't work, probably something to do with the wiring internals of the cable.
Jonah
Paul-RS
Post by Paul-RS » Tue Oct 14, 2003 6:25 pm
lol. same arm i twisted and then gave it to Dunc [img]images/graemlins/cool.gif[/img]
never did try it as i never got a laptop
RevoKev
Post by RevoKev » Tue Oct 21, 2003 12:00 pm
What was meant by this was that VAG-COM can be using to monitor the likes of actual/requested boost, timing, AIT, etc, etc. thus allowing you to use the SPS 3 more effectively to set the most efficient settings!
