I am thinking I should pressure test the coolant system once I have the engine built and before I put it back in the car ... because of new turbo's etc going on, there is obviously a real chance of a leak somewhere...
How is this done, do I need to get some kind of adapters made up, like in the same way as the pressure tester for the air intake system?
Pressure Test Coolant System?
RE: Pressure Test Coolant System?
just buy a tester with the correct adaptor for the screw thread on the coolant bottle..then pump it up to the req pressure..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Yeah, that makes sense Simon, I was not sure if I could it without connecting up the whole system, but on thinking, what would be the point in just testing half of it!!
Dont forget the vw/audi pink coolant additive.... extremely helpfull on recognising leaks ..... plus it protects ..
happy dayz .... party ....
Blue_Thunder
- Top Gear
Re: RE: Pressure Test Coolant System?
And, as I found out recently, it makes your parking space a pretty colour if you've got a leakrolskii wrote:Dont forget the vw/audi pink coolant additive.... extremely helpfull on recognising leaks ..... plus it protects ..
