need to upgrade rear brake setup
aposegil
Post by aposegil » Thu Feb 21, 2008 2:57 pm
Hello all
well I have succesfully fitted the front RS4 B5 discs calipers to my passat but I am now finding the braking unbalanced. Fronts will lock up under heavy breaking (abs saving me) and rears feel like they are doing nothing now.
At the moment I have 245mm discs on the rear (stnadard) but I was thinking of upgrading rears to rs4 or if I can get away with big A6 or A8 possibily s6/s8 setup I would.
has anyone had to upgrade there rears?
alex
electric van for work
a4 v6 3.0 vortex sports for her
sold B5 passat 2.7T rs4/rs6 hybrid 477.17 bhp/471.98 lbs (483ps/640nm)
ZX9R sold replaced by hayabusa just because
Corrado vr6 turbo for fun
s4woody
RE: need to upgrade rear brake setup
Post by s4woody » Thu Feb 21, 2008 3:38 pm
GARTH ROAD MOT CENTRE LTD
020 83353032
aposegil
Post by aposegil » Thu Feb 21, 2008 3:48 pm
pm sent
alex
aposegil
Post by aposegil » Fri Feb 22, 2008 12:16 pm
ok still looking for information
I found the RS4 rears are 312mm (max i can go) and very common setup across A6/A8 v8 lump and S6 and S8 is 269mm setup at the rear.
Does anyone else know what other setups out there?
alex
JonnyX
Post by JonnyX » Fri Feb 22, 2008 12:27 pm
2001 S8 is also 280mm rear. AP racing do a rear setup for the B5 RS4 but they are pretty huge I think.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
aposegil
Post by aposegil » Fri Feb 22, 2008 12:28 pm
see I would be happy with 280mm rear setup just got to find someone breaking a S8 lol
dont really want to go over 310mm (standard RS4) because that meant ill have to much at the rear and back end start locking up. At the mo i have the front locking up :(
alex
MarkB
Post by MarkB » Fri Feb 22, 2008 12:35 pm
Mark
aposegil
Post by aposegil » Fri Feb 22, 2008 1:00 pm
damm so basically i have as standard as a normal S4 245mm at the rears
Just buy that bracket from over there means I can now run 300mm discs. But what discs are these off? Just standard B7 S4?
Or am I better of source parts of a S4 here becuase I assume handbrake cable and brake lines will need changing
alex
MarkB
Post by MarkB » Fri Feb 22, 2008 1:07 pm
Are you current rear brakes vented?
New brake lines will be required AFAIK but you should be able to shift the handbrake cable
Mark
aposegil
Post by aposegil » Fri Feb 22, 2008 2:18 pm
mine are identical to S4 245x10mm
so at a guess its not vented so mean i will need caliper and carrier
alex
JonnyX
Post by JonnyX » Fri Feb 22, 2008 2:28 pm
Facelift S4 calipers are about 100 quid each from Vagparts
S8 280mm disks, carriers and pads will set you back about another 250
Not sure if your brakelines for handbrake are OK as you have the non-vented setup.
Seriously, speak to Doug@MRC. He'll be able to give you some options.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Users browsing this forum: No registered users and 85 guests
