RS6 brakes
RS6 brakes
I'm going to be fitting rs6 front and rear brakes to my A6 2.7T does anybody know if i'm going to need brackets made up or will they be ok as it is from the A6 family.
RE: RS6 brakes
the rs6 brackets will probably do the job if you get them complete with calipers otherwise probably need brackets as the caliper will sit out further due to the size of discs, easy enough to have made.
S4 Crazy Horse. Ringsticker & MRC black magic.
RE: RS6 brakes
Does it really?? I thought you needed custom brackets?
Not sure about the rear? I think the B7 RS4 rear brakes are a straight fit. I think the RS6 ones are a real problem to fit. Doug has it on his car and advises against it.
RE: RS6 brakes
Doug's is a s4 if I'am right? is there a difference between my 2.7T A6 and the S4/A4 the rears look easyer then the fronts.
1.9TDI A6 are sh*t wrong forum
