Mis fire under load
david7m
Mis fire under load
Post by david7m » Tue Dec 12, 2006 10:30 am
Hi
I have came into work this morning and under load (more noticeable from 3k) it mis fires and holds back, was also flat as a pan cake after 4k :(
The engine management light came on (flashing not constant) so I pulled over, but then it stopped. It did this twice.
Below 3k/cruising it was fine, but hard acceleration/load was the issue.
I had coil packs about 30k ago, do you think one or more of these have gave up?
Cheers,
Dave
PS Do not have VAG COM.
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
littleblue
RE: Mis fire under load
Post by littleblue » Tue Dec 12, 2006 6:43 pm
could be plugs.....
Nogaro Blue S4 Avant thats now sold 3/3/07
DuncS3
Post by DuncS3 » Tue Dec 12, 2006 6:55 pm
sounds like coil packs to me - especially when you said that it made the engine light come on
david7m
Post by david7m » Thu Dec 14, 2006 11:17 am
I've cruised into work the last few days changing gear at 2.5k rpm, with no problems. This morning I built up the revs slowly to 4k, and it was fine.
Would the coil packs only break down under hard acceleration? Or is it something else?
Dave
MarkB
Post by MarkB » Thu Dec 14, 2006 11:29 am
I think they could be affected by heat or damp maybe? So you didn't try nailing it this morning then?
Mark
david7m
Re: RE: Mis fire under load
Post by david7m » Thu Dec 14, 2006 11:38 am
MarkB wrote:I think they could be affected by heat or damp maybe? So you didn't try nailing it this morning then?
Nah, couldn't risk a complete shutdown on the way to work ;) May try on the way home............
We've had little rain down here recently and the engine is ran for 40 mins each journey, so doubt damp would be a problem.....
Dave
derdle
RE: Re: RE: Mis fire under load
Post by derdle » Thu Dec 14, 2006 8:02 pm
Is there anyone near you with VAGCOM...just to see if there are any fault codes?
Ooops ....jsut seen your post asking for VAGCOM nr MK!!! Doh!
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
david7m
Post by david7m » Sun Dec 17, 2006 8:44 pm
Sorted Friday night, it was a mis fire on cylinder one - new coil pack, job done :)
Dave
