fitting / connecting a boost gauge
fil
Post by fil » Sat Dec 02, 2006 12:09 pm
B5 S4, ive seen a how to somewhere, but cant find it?
was going to mount it in one of the centre vents, and tap the bulbs ( to be replaced with a red led ) power supply off the vent lights?
but want to see pictures if poss of where the air pipe is run and T'd into the supply?
from here if anyones intersted , https://www.burtonpower.com/default.asp ... st%20gauge
s4woody
re
Post by s4woody » Sat Dec 02, 2006 2:04 pm
i took my vaccum from the fuel pressure regulator on my engine..
if you look at the picture you will see a small red hose to the rite..thats it..
Picture 441.jpg (111.91 KiB) Viewed 806 times
GARTH ROAD MOT CENTRE LTD
020 83353032
shineydave
RE: re
Post by shineydave » Sat Dec 02, 2006 2:24 pm
just taken a break from fitting mine. i've tapped the power for the light from the X75 terminal at the bottom of the relay board so the light comes on with the main dash lighting. just having a coffee then going out to remove the ECU to get the pipe into the engine bay. i'll post some pics of the pipe run in an hour or so when i'm done.
fil
RE: re
Post by fil » Sat Dec 02, 2006 2:24 pm
will put it all in if i get chance thisweek, then if im not 100% sure on the cutting will take a closer look at yours , say saturday :)
99 S4 minging blue avant
MCB
RE: re
Post by MCB » Sat Dec 02, 2006 2:41 pm
AWE Tuning have fitting instructions - download the PDF - on their website should help.
S4B5 Avant
fil
RE: re
Post by fil » Sat Dec 02, 2006 2:53 pm
printing it now, knew i'd seen it somewhere
shineydave
Post by shineydave » Sat Dec 02, 2006 3:34 pm
pics of the pipe routing from inside the ECU housing to the T piece. i pulled the grommet in the bulkhead out as it was easier to cut the nipple off and pass the pipe through it with it out.
s4woody
Post by s4woody » Sat Dec 02, 2006 4:42 pm
that grommet next to the grommet you have pulled out dave is where mine goes through to the ECU box.. i just cut a slot into it and passed it under the ECU loom then into the ECU box then along the underside of the dash and into the centre vent..
020 83353032
shineydave
Post by shineydave » Sun Dec 03, 2006 12:28 am
did you get the AWE kit? i just had enough hose in it to go in a straight line from the ECU to the fuel reg, if i'd have followed the loom i'd have had to use the force to make a connection
MCB
Post by MCB » Sun Dec 03, 2006 1:16 am
I think we all thought you had this? :lol:
S4B5 Avant
shineydave
Post by shineydave » Sun Dec 03, 2006 9:59 am
yup, that's why it took me 3 hours instead of the 1 they say on the AWE website. prolly have been easier if the pipe had had some length to it
s4woody
Post by s4woody » Sun Dec 03, 2006 2:36 pm
the pipe i got came with it.. i did have sum left over so yes was prob easier to fit..
020 83353032
