TTE700 Upgrade Performance Turbocharger 2.5 TFSI TTRS 8S, RS3 8V.2
https://www.TheTurboEngineers.com - The Turbo Engineers are one of Europe's leading forced induction specialists, with renowned expertise in the field of VAG turbochargers.
TTE Si
Site Sponsor
Post by TTE Si » Tue Sep 11, 2018 12:25 pm
Introducing our TTE700 performance turbocharger based on the original turbocharger to new higher output specification. Offering an upgrade power upto 700PS
Engineered & Enhanced
At the core of our TTE700 is a much larger TTE compressor wheel, chosen because it is highly efficient and creates an extremely high flow for comparative size. Re-Profiled compressor cover to optimised tolerance to ensure maximum compressor efficiency is given.
We CNC mill the exhaust turbine housing to accept a larger turbine and shaft.
Special profile 360 deg high-performance motorsport journal bearing is fitted, to remain durable at higher loads with no loss in transient response. The actuator used is sprung OE unit
Equilibrium
Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in-house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
Product Highlights:
• Up to 700HP / over 900Nm
• Original BWTS turbocharger as base part
• Very early response
• Billet Milled TTE compressor
• Reinforced BWTS TTE actuator
• High Flow Turbine
• O-ring sealing
• Reinforced axial and radial bearing
• Proven TheTurboEngineers quality
• TTE CNC milled OEM intake pipe included
• Made in Germany
Pricing : https://tteglobal.com/audi/rs3/8v.2-2.5 ... r=TTE10032
Upgrade Injector set required for max output
https://tteglobal.com/audi/rs3/8v.2-2.5 ... jector-set
Our TTRS 8S 102 RON, 34 deg ambeint temps
Email : sales@theturboengineers.com
FACEBOOK LINK https://www.facebook.com/TheTurboEngineers/?ref=hl
IMPRESSUM & LEGAL NOTICE http://www.theturboengineers.com/#!impressum/acaky
TTE Si
Site Sponsor
Re: TTE700 Upgrade Performance Turbocharger 2.5 TFSI TTRS 8S, RS3 8V.2
Post by TTE Si » Sat Oct 13, 2018 9:22 am
D.H Automotive AUDI RS3 8v.2 with our TTE700 upgrade hybrid turbo fitted. (stock engine & transmission)
732PS 913Nm 💪🏻
MRC Software using Race 109 octane fuel
Graph shows a comparison to a stock RS3 (red lines). As you see no loss in response👌🏼
#TTEPOWER #TTE700 #FASTSPOOL #RS3
TTE Si
Site Sponsor
Post by TTE Si » Tue Oct 23, 2018 9:24 am
Testing our TTRS 8S TTE700 hybrid last tonight on an Autobahn 100-200 kmh
Pump 102ron fuel 1/2 tank. full weight
TTE Si
Site Sponsor
Post by TTE Si » Thu Oct 25, 2018 1:00 pm
RS3 Saloon TTE700 D.H Automotive
Full weight, 99 fuel using MRC Software
100-200kmh 5.41 sec Dragy GPS timer
#TTEPOWER #TTE700 #RUNTTE
TTE Si
Site Sponsor
Post by TTE Si » Sun Nov 04, 2018 7:59 pm
Well done to Dave Henderson for making a 9 sec 1/4 mile pass and pulling a 4.9 100-200kmh run today in his RS3 8V Saloon TTE700
Jumped from 19th to 8th on TTE OWNERS TIMES 100-200
and went 5th at the 1/4 mile just behind a 997 TTE800 VTG way over 800HP...
https://www.theturboengineers.com/100-2 ... 64mAwVJnRA
EUROPES FASTEST RS3
BIG UP ALL INVOLVED
TTE Si
Site Sponsor
Post by TTE Si » Thu Nov 08, 2018 12:51 pm
2018 TTRS 8S
spec:
SAR Intercooler, SAR down pipe with 2 X Catalyst, SAR Turbo intake, MTR injectors, TTE700 turbocharger, MTR performance software
15 degrees ambient temp, driver 115 kg, Full tank 102 aral, car series weight with OEM 20" alloys.
670 HP 800 NM
● 100-200 5,08 vbox corrected
● 200-250 4,66 Vbox corrected
More to come with some weight saving and mods...
#MTRPERFORMANCE #TTE700 #TTRS #RS3
TTE Si
Site Sponsor
Post by TTE Si » Sun Jan 20, 2019 11:01 am
Audi TT RS 8S 2.5 TFSI by BR-Performance Nederland
Stock : 400 Hp / 480 Nm
Stage 3 : 620 Hp / 768 Nm (low boost)
- TTE700 Turbo TTE INLET
- Forge Motorsport Competition Intercooler + Hoses
- CTS Turbo decat Downpipe
- Eventuri Carbon Air Intake
- BR-Performance Stage 3 custom remap +
Stage 3 S-Tronic remap + Rev limiter OFF
- Firezone 102Ron
#TheTurboEngineers #Forgemotorsport #BRPERFORMANCE
Return to “The Turbo Engineers”
Users browsing this forum: No registered users and 3 guests
