TTE950+ RS4, S4 B5 Upgrade Turbochargers
https://www.TheTurboEngineers.com - The Turbo Engineers are one of Europe's leading forced induction specialists, with renowned expertise in the field of VAG turbochargers.
TTE Si
Site Sponsor
Post by TTE Si » Wed Jul 27, 2016 9:53 am
Our biggest power solution for the AUDI 2.7T V6 Power plant, aimed and designed for the power elite B5 owners like Philipp Kaess with the infamous RS4 Limo that holds multiple records for the B5 platform. Huge amount of development tuning this turbo spec to create ultimate high power with good boost response.
Engineered & Enhanced
TTE950+ Turbochargers are based on Genuine BorgWarner Porsche K16 turbine housings and cores with Genuine BorgWarner compressor covers with TTE billet anti surge inlets.
TTE CNC machine in house the Genuine BorgWarner compressor cover to allow fitment and maintain efficiency of a larger highly advanced billet milled 7+7 blade high pressure compressor wheel and for fitting the TTE billet Anti surge 63.5mm inlets.
The Compressor wheel is a TTE 7 bladed billet milled high pressure anti surge geometry compressor wheel, features promote greater airflow and pressure using a low inertia wheel that performs like a wheel of even greater size and mass. 7+7 Blade technology enables lower boost threshold giving the user faster spool-up at lower engine speeds while providing the high boost with much less heat for powerful top-end performance.
The K16 exhaust turbine housings are CNC milled in house to allow fitment of the larger K24 turbine to a optimum clearance for maximum efficiency. We also modify exhaust entry port from a stock size diameter, increasing the size of the throat to increase the flow capacity before the turbine and perform other modifications after the turbine for increased performance.
Turbine and shaft being BorgWarner (Porsche) K24 items. K24 turbine is clipped at BorgWarner. Clipping reduces the blade area thus increasing gas flow and so reduce back pressure and lowering exhaust gas temperatures, allowing safer higher boost level's. This clipping also gives a secondary advantage of removing some material, lightening the turbine thus reducing rotational mass improving moment of inertia and spool.
Genuine BorgWarner motorsport 360 deg journal bearing system are fitted, to remain durable at higher loads with no loss in transient response.
Actuators used are uprated sprung OE units fitted with our reinforced clamps for trouble free operation. These also can also be modified/set to customer needs and specifications. These are supplied in kit form to allow the end user to custom fit as required.
Equilibrium
Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
Key Points
Genuine BorgWarner compressor housings with Billet TTE anti surge 63.5mm inlets (Viton O-Ring seals inc)
Genuine BorgWarner K16 exhaust housings, Ported & Modified for greater gas flow
TTE Latest Billet Highly Efficient Next Gen compressor geometry
Genuine BorgWarner K24 Turbine, Clipped & lightened
Genuine BorgWarner Reinforced Motorsport bearing system
Genuine BorgWarner Modified reinforced actuators supplied in kit form for custom fitment
Single parts finely balanced then components assembled and high-speed VSR balanced
Supplied with a serial numbered balance test document for each turbocharger
1080PS proven on e85
Designed, Machined & Built by TTE in Germany
Brand new Price is 4536.97 Euro net
(For customers in EU countries 19%+ VAT Must be added to prices above unless have a valid VAT ID)
ATTENTION:
These turbochargers need custom installation are not Plug & Play.
Email : sales@theturboengineers.com
FACEBOOK LINK https://www.facebook.com/TheTurboEngineers/?ref=hl
IMPRESSUM & LEGAL NOTICE http://www.theturboengineers.com/#!impressum/acaky
TTE Si
Site Sponsor
Re: TTE950+ RS4, S4 B5 Upgrade Turbochargers
Post by TTE Si » Wed Jul 27, 2016 10:05 am
Complete TTE850+ OR TTE950+ packages available from THE-TUNER https://www.facebook.com/THE-tuner-463958107050886/
TTE850+ THE-TUNER PACKAGE
TTE950+ THE-TUNER exhaust manifolds and inlets Ceramic Coated
IanH755
Post by IanH755 » Wed Jul 27, 2016 4:15 pm
***OLD*** Daytona C5 RS6 Avant - MRC'd - 500HP & 820NM (PH Link).
***NEW*** Daytona C6 RS6 Avant - MRC'd - 907HP & 1130NM (PH Link)
TTE Si
Site Sponsor
Post by TTE Si » Wed Jul 27, 2016 6:04 pm
IanH755 wrote:Your link is broken Si.
https://www.facebook.com/permalink.php? ... 8107050886
Strange as works for me. Thanks for info !
Try this : https://www.facebook.com/THE-tuner-463958107050886/
IanH755
Post by IanH755 » Wed Jul 27, 2016 7:38 pm
Looks like my work PC is the issue Si, those links are fine on my Home PC.
TTE Si
Site Sponsor
Post by TTE Si » Thu Aug 04, 2016 9:29 am
S4 3.0 1088PS 1239Nm
TUNETEC Software
TTE Si
Site Sponsor
Post by TTE Si » Thu Aug 04, 2016 9:34 am
TTE Si
Site Sponsor
Post by TTE Si » Fri Oct 07, 2016 4:32 pm
TTE Si
Site Sponsor
Post by TTE Si » Mon Nov 14, 2016 3:28 pm
The notorious RS4 TTE950+ Limo of Hannover Hardcore pulling deep into the 300+ Kmh zone.
Shot taken from JTmedia.fi youtube video : https://www.youtube.com/watch?v=4RNsVkUWFnk
TTE Si
Site Sponsor
Post by TTE Si » Fri Feb 03, 2017 11:05 am
ULTIMATE B5 STARTER KT
THE-Tuner TTE950+ kit
TTE Si
Site Sponsor
Post by TTE Si » Fri Feb 03, 2017 11:15 am
AUDI S4 B5 TTE950 1/4 Mile 2016 10,5s 221 Kmh
TTE Si
Site Sponsor
Post by TTE Si » Fri Feb 03, 2017 12:08 pm
Philipp of Hannover Hardcore Audi S4 B5 3.0 TTE950+ Running a 10.19 Sec 1/4 mile @149.12MPH and with a slipping clutch in 4th gear.
TTE Si
Site Sponsor
Post by TTE Si » Fri Oct 27, 2017 4:10 pm
TUNETEC PROJECT 1 xxx ps complete!
THE VEHICLE GOT 2 mappings during the trip switchable:
1 Level 857 PS / 978 NM LD 2,1 @ 1,9 bar
2 Level 1013 PS / 1156 NM LD 2,6 @ 2,4 bar
Engine design and software by TUNETEC , mechanical implementation took place by my werkstattpartner Bernhard Reitsamer e.U., at this point again my sincere thanks for the implementation and completion of the vehicle after a long odyssey in "Just 3 weeks" - top performance berni (y)
Rough list of built components:
- loader TTE950+
- exhaust manifold the-tuner
- intake pipes the-tuner
- Nozzles 1450 CC E-100 fit
- system 3,8 bar
- 3 x pierburg e3l
- Catchtank
- enlarged benzinleitung before and back
- Fuel E-80
- Wmi-Boost Cooler with 2 Nozzles
- 3.0 l block
- rec piston
- Rec rods
- Compression 8,2: 1
- camshafts suction
- Suction Heads
- reinforced ventilfedern
- modified valves
- DK Rs4
- and-Rohr series
- Llk the tuner
- wagner intercoolers
- Hfm Case 95 mm
- trousers pipes 70 mm
- Exhaust System 76 mm from Kat to 90 mm wilke
- gearbox reinforced
The vehicle comes back to us in the spring of 2018 to get another upgrade, which will include the following parts:
- CNC milled heads of ng motorsport
- modified camshafts
- DK Rs6
- the tuner pipes
- the tuner inlet bridge
- the tuner y-tube
We're excited to see how much performance is on top of it.... stay tuned
TTE Si
Site Sponsor
Post by TTE Si » Wed May 30, 2018 10:43 am
BMW S1000RR Vs AUDI S4 B5 TTE950+
Build and tuning by SnakePerformance 👏🏻
2.3 bar ecu Software 🙌🏻
30deg Ambient temps
100-200kmh 3.7 sec(2.7bar)
#TTEPOWER #TTE950 #SNAKEPERFORMANCE #1000HP #BMWS1000RR #B5Elite
TTE Si
Site Sponsor
Post by TTE Si » Thu Nov 01, 2018 1:08 pm
RS4 B5 TTE950 using THE-Tuner hardware
948PS 1063NM 102 RON fuel 2.5bar
Return to “The Turbo Engineers”
Users browsing this forum: zex and 2 guests
