rs2 seat rattles
Posted: Sat Oct 08, 2011 9:45 am
by wowow
My front seats (both) has a lot of "play", ie, if you shake them, they will rattle. The previous owner of the car has retrimmed the seats but somehow he must have left out some parts when putting the seats back into the railings. I can see the "wheel"on the seat base moving when I shake the seats. I like to know if my guess is right, or the car do have that problem, and any suggestion as to how to solve that. thanks
as you can see in the photo, the "wheel"is outside of the railings and there is a rectangular metal piece in the railing but it is not thick enough and therefore result in lots of play.
Re: rs2 seat rattles
Posted: Mon Oct 10, 2011 3:47 pm
by Shoppinit
I have had this. THere's a missing bit of plastic that goes between the spigot and the rail. Have a look around under you seat to see if you can find it.
It might have just disintegrated.
Posted: Mon Oct 10, 2011 3:53 pm
by Shoppinit
Looks like part numbers 893 881 203A and 893 881 203, outer and inner respectively.
Posted: Mon Oct 10, 2011 7:42 pm
by teknobod
Definitely the nylon guides as shoppinit mentions.
Had to replace them on mine. If you're removing the seat to fit them, I'd also replace the front centre one, where the release lever is mounted which is another common problem. (Same setup as Golfs etc of the same era)
Andy
Posted: Mon Nov 21, 2011 4:38 pm
by wowow
many thanks guys
