Low idle speed
Posted: Sat Jul 17, 2010 2:55 pm
by RS2Nut
Hi,
I notice my car is idling at about 600 rpm which makes it quite lumpy at idle.
I have also found that when I turn on the AC the engine hunts up and down, to the point of allmost stalling,
Are these things connectd ?
What dictates the idle speed and is it adjustable.
Appreciate your advice.
Regards
PAUL
Posted: Sat Jul 17, 2010 6:38 pm
by scillyisles
Sounds like your Idle Stabilisation valve is dirty and needs to be cleaned.
Posted: Sun Jul 18, 2010 12:45 am
by RS2Nut
Thanks scillyisles,
But, where is the idle stabilisation valve located and how do I clean it. Do you know if it is an expensive part ?
PAUL
Posted: Sun Jul 18, 2010 11:44 am
by scillyisles
The ISV is just behind the intake manifold where the accelerator cable attaches. Look at this pic here it is the valve that sits behind the mainfold just in front of the front crossbrace . It has black tubing attached to it and is cylindrical in shape. They often get dirty and cause the symptoms you are getting (mine did) They can be cleaned by rinsing in petrol. http://pictures2.autotrader.co.uk/imgse ... 1314211510
I don't know the part cost but I would have thought it was not too expensive.
Posted: Thu Jul 22, 2010 5:47 pm
by DH79
Just had very similar symptoms rectified by replacing the MAF....
Posted: Thu Jul 22, 2010 9:13 pm
by RS2Nut
hi,
Downloaded the faulkts on VAGCOM today and it showed a faulty Lambda Probe....
Will replacwe it and let you know if that cures it..
PAUL
Posted: Fri Jul 30, 2010 6:27 pm
by RS2Nut
Update
Replaced lambda probe, problem solved.
Got a Bosch one from Euro Car Parts for £47 delivered, was not straight forward though because you need to splice the cables. Took about 15 minutes....
Very smooth now...
Still idling a bit low so will give the ISV a clean and let you know ...
Regards
PAUL
