Aero Wipers - HELP
Posted: Thu Jul 08, 2010 5:39 pm
Hi guys,
Want to upgrade my RHD RS2 to latest aero wipers but having problems with finding the right arm / blade combination. This is what I have tried so far.
Retrofit wipers work but are ugly....
Got a set of arms & blades from 2007 A6 avant, very nice design using 22" blades. Drivers side is fine but passenger side arm is too long and the blade sticks out a few inches past the screen when parked. Have bent the arm but still not enough, I know some people have used a shorter blade on the passenger side but that must look a bit wierd and would have to be 20" or less to work.
I know there are lots of posts regarding aero wipers but they are fairly old and focus on the VAGPARTS upgrade kits which are , sadly no longer available.
Questions -
1) Can anybody tell me which donor car (model and year) I can use as a straight swop.
2) Is there a matching passenger side arm for my 2007 A6 drivers side arm that uses the same fixing (am I correct that an A4 from 2007 would use the same blade fixing as the A6 from the same year ?)
3) What is the details of the upgrade for the rear, and will the washer function work as it should ?
Appreciate any advice you can give.
PAUL
Questions -
PAUL
