Water leak
Posted: Wed Jan 20, 2010 8:59 pm
by PAULRS2
Just noticed a small amount of water dribbling in to my car from the passenger side of the dashboard , does anyone know where this could be coming from I hope the photo shows where I mean it's dropping into the car where you can see the red paint
Thanks Paul
Posted: Wed Jan 20, 2010 11:16 pm
by scillyisles
Have you had a replacement windscreen fitted at some stage - looks like it could be from there.
Posted: Thu Jan 21, 2010 7:56 am
by PAULRS2
scillyisles wrote:Have you had a replacement windscreen fitted at some stage - looks like it could be from there.
No mate it's the original screen, someone on another forum has mentioned it could be loose door seals or sunroof drains but I've been told the sunroof drains are fine and the door seals look okay to me aswell
thanks Paul
Posted: Thu Jan 21, 2010 1:13 pm
by scillyisles
Yes loose door seals would be my second suggestion - I have recently had this issue on the rear passenger door. You might need to adjust the passenger door as over time the hinges might have sagged.
Posted: Thu Jan 21, 2010 7:30 pm
by PAULRS2
scillyisles wrote:Yes loose door seals would be my second suggestion - I have recently had this issue on the rear passenger door. You might need to adjust the passenger door as over time the hinges might have sagged.
Thanks mate this could be it as the door has sagged, but would this allow water to get in when it's closed
thanks Paul
Posted: Thu Jan 21, 2010 9:24 pm
by scillyisles
Yes - the seals at the top and leading edge of the door rely upon a very tight fit. As the door sags that fit becomes loose and the water gets past the seal. Once water has got past this seal then there is nothing to stop it dripping down into the car. On the leading edge the water would tend to to follow the door frame down towards the area in your photograph
Posted: Thu Jan 21, 2010 9:31 pm
by PAULRS2
scillyisles wrote:Yes - the seals at the top and leading edge of the door rely upon a very tight fit. As the door sags that fit becomes loose and the water gets past the seal. Once water has got past this seal then there is nothing to stop it dripping down into the car. On the leading edge the water would tend to to follow the door frame down towards the area in your photograph
Thanks a lot mate getting the door sorted next week so hopefully will cure the leak
