humming sound after driving for about 2 hours.
Posted: Thu Aug 13, 2009 7:12 pm
by Richardrs2
Hi all. I am getting a hunning sound from the front of the car which comes and goes but it only does it when the car / transmission is hot after about 1.5 hours of normal driving.
Any help whould be great.
Richard RS2
RE: humming sound after driving for about 2 hours.
Posted: Fri Aug 14, 2009 9:00 am
by alastairg
Brake pads failing to sit back in the caliper due to galvanisation build up between the steel backing clip & aluminium caliper body. Common issue & my educated guess. Wheel bearing usually an issue from the moment you set off.
Posted: Fri Aug 14, 2009 7:28 pm
by Richardrs2
Ok thanks. Would this not make the noise all of the time though not just after 1.5 hours when hot ?
Does anyone know that the situation is with diff / gearbox oil changes ? If the oil was getting hot due to a low level could it make a humming sound from the diff or gearbox ?
Posted: Sun Aug 16, 2009 7:51 pm
by alastairg
Unlikely but worth changing the oil.
Posted: Sun Aug 16, 2009 10:51 pm
by teknobod
Prop centre bearing?
Mine does it after 1.5-2 hours.
Andy
Posted: Mon Aug 17, 2009 9:40 am
by alastairg
Possible, however mine gave a noise with the car stationary on throttle lift off @ 3.5k & under load with lift off throttle. You get the noise of that bearing when worn when you create load & Xs movement & then noise. It would not cause a constant noise on the run in my experience. Its the calipers
Posted: Mon Aug 17, 2009 12:44 pm
by AlWyn
Difficult without hearing the noise but i had a simular sort of noise from the offside front which was the calipers/pads issue Alistair mentioned which is well documented and the huge amount of brake dust that had built up... mine was all sorted with new calipers and pads.
