Air con problems
Posted: Sat May 30, 2009 6:06 pm
by trevithick
The problem being it doesn't work.
The light comes on and the fan runs but the compressor isn't engaging. i've put 12 v to the comp. and it engages fine.
I've noticed that relay 6 is missing, I swapped the horn relay into the position and it engages but still no compressor.
Has anyone got an idea of what is wrong and does anyone have a wiring diagram for this system, that would help (I'm an electrical engineer so I stand a fighting chance).
HELP its' a black car and the summer's comming and we're getting a bit hot.
T
RE: Air con problems
Posted: Mon Jun 01, 2009 6:50 am
by venetors2
Hi
A common fault it's the multifuzzi F76 sensor located under the inlet manifold on the water rail.
You can see the F76 here:
http://www.audisportclub.com/forum/showthread.php?t=114
The multifuzzi F76 it's used for the water gauge on the dashboard and......
to protect the engine if overheated by disengaging the aircon compressor until the temperature comes to normal value.
Sometimes it stays triggered in that protection position so your aircon does'nt kick in.
It's easy to find out if the F76 it's the cause of your fault:
Loose gently the rubber cap and pull off one wire per time if the air con kicks in on loosing one of them you got it.
You have then two options:
1) change the F76 (quite expensive)
2) live the wire loose and just be careful in very high temperature to keep an eye on the water temp gauge.
On my old S2 i left the wire detached for years without any problem (and i live in Italy...)
Hope the reason of your fault it's this anyway.
Stefano
Posted: Mon Jun 01, 2009 8:25 pm
by trevithick
Cheers for that I'll have a look.
T
Posted: Mon Jun 01, 2009 11:02 pm
by Cornishmoocher
Could be..... sounds like an ass about face way of doing things tho.......over engineered again!
Posted: Tue Jun 02, 2009 6:12 am
by trevithick
Found the problem, the mooch was right, no gas!
I opened the HP port and it sounded like Elton John farting so I suspect I've got a leak, all I have to do is find it
T
Posted: Tue Jun 02, 2009 6:42 am
by Cornishmoocher
Careful......
It could have just leaked thru the shaft seal thru lack of use.
I am away up to kent now, but will be back Thurs/Fri, check to see if it is 134a, and I will meet up with you and charge it up you will need to PM me on SRS as I cannot acsess this site from my work Laptop for some dumbass reason, and let me know if you have any.
Cheers Mooch
Re: RE: Air con problems
Posted: Tue Jun 02, 2009 12:10 pm
by DickyC
trevithick wrote:Found the problem, the mooch was right, no gas!
T
You didn't do what dad said, did you?
"The air con gets tired but an annual recharge is about £40." It's in Vol 27 of my pre-sale ramblings
It's just the seals getting old. Use it constantly - yes even in the winter - to keep the seals awake and it should just need one recharge a year. I asked Audi to put dye in it last time to identify the leak, but they reckoned they couldn't.
You still on for Sunday at Goodwood?
Marvellous.
Posted: Tue Jun 02, 2009 7:04 pm
by rs2315
Gas, dye, oil went into my system, so Audi 0 specialists 1 again
rs2315.
Posted: Tue Jun 02, 2009 7:38 pm
by scillyisles
AIRC the RS2 has a different A/C connection type than modern Audis and therefore your Audi dealer might find it difficult to connect to the high and low pressure side of the A/C system in order to refill the system and put the dye in.
With the right connection it is no problem - my system has dye in it to detect for leaks but I do remember my Audi dealer having this problem until the right connector was obtained.
Posted: Tue Jun 02, 2009 8:10 pm
by trevithick
I've managed to get some gas in it so I've got cold air now. The fittings are standard quick release ones from the local air con people.
I'll have a go with the dye etc next week and see what damage I can do!
Goodwood hope so but I have a knackered exhaust manifold and racing slicks now, so I may have to save my pennys. Lets hope some of my clients decide to chough up, if not it'll be SORN.
T
