Climate Control problems
Posted: Thu Sep 04, 2008 1:31 pm
I've owned my RS2 for about 4 1/2 years and it's a great car - with one exception. It's a LHD model with automatic climate control system. When I first bought it everything worked fine, but gradually the system has become increasingly unreliable. Initially it started to refuse to direct air to the windscreen vents. Now all it will do is provide unheated or freezing air conditioned air split between the windscreen and footwells. No heating and no ability to change the direction of air flow. Earlier in the year I left the car with a specialist whilst working abroad, and they drew a blank. All parts of the system seemed to work when tested in isolation, but when the control panel is installed it doesn't work, which suggests a control panel fault. However, when a panel from another car was tried I believe the same problems occurred, and my panel appeared to work OK in the other car.
I would really appreciate it if anyone has any ideas, or can point me in the right direction, otherwise the car is going to become virtually unusable in the colder weather. It is my only car and I don't want to have to get rid of it due to this apparently trivial problem!
