Page 1 of 2
Handling...
Posted: Wed Feb 28, 2007 12:44 am
by Lloyd
I've had a good look through the info on the forum regards understeer and toe/camber/castor etc but wanted to ask again for any recent developments or advice....
I want to try and reduce the inherent understeer on the car - especially on-power understeer by tweaking the geometry. Has anyone any proven recommendations?
The car is presently stock, with new wishbone bushes, top mounts and a recent 4 -wheel alignment. There will be a 19mm Neuspeed RARB with poly bushes fitted in 3 weeks courtesy of Corey at Quattronics.
Any suggestions welcome.
Cheers,
RE: Handling...
Posted: Thu Mar 01, 2007 10:15 pm
by alastairg
Standard settings with -1o camber works really well. Great turn in with reduced understeer. Wish I had tried it years ago
Posted: Fri Mar 02, 2007 3:41 pm
by Lloyd
Cheers Alastair, I will give it a whirl. Probably worth a bit more tyre wear to make it a more pointy and reduce understeer.
Posted: Fri Mar 02, 2007 5:34 pm
by alastairg
Defo more tyre wear but handling sharp. Just front mind. I will go to -0.5o front camber next time round
Posted: Sat May 12, 2007 4:53 pm
by AAH!
Lloyd
how did the Neuspeed RARB work out?
My OEM RARB is looking a little worse the ware, with the coating having nearly all flaked off and the surface of the RARB in a very weathered condition i.e rusty.
My 4 wheel alignment place suggested replacing it. Any comments anyone?
Angus
Posted: Sun May 13, 2007 6:33 pm
by Lloyd
Hi Angus,
Personally, I can recommend the Neuspeed 19mm and the 'kit' that comes with it. I've only been driving with it on the weakest setting which I think is still about 3x RS2 torsional stiffness.
Anyway, it really reduces understeer, especially on power understeer when coming out of bend and has not noticiably made it any more oversteery - yet.....
A bit less body roll through bends too - I'm considering upping the setting to medium next....
I think it is a good upgrade.
Cheers,
Posted: Tue May 15, 2007 7:34 pm
by rs2315
Nexus27 wrote:Hi Angus,
Cheers,
Lloyd, what dampers are you using?
Bilstein dampers with the rear modifacation I've been told work a treat with oe springs.
rs2315.
Posted: Thu May 17, 2007 10:24 am
by Lloyd
I'm on OEM stock suspension + Neuspeed RARB.
I've heard that the S4 billie's work well, it's just that I had Billstein on a previous car and they were hard as nails.... I'm just a bit concerned that fitting them to the RS2 will turn it into a bit of a bone shaker...
If anyone has them fitted with stock springs pls let me know!
Cheers,
Posted: Thu May 17, 2007 3:39 pm
by alastairg
alastairg wrote:Defo more tyre wear but handling sharp. Just front mind. I will go to -0.5o front camber next time round
I am still at -1o and all is well. The tyre wear is not an issue as I was not taking into account the abnormal wear from not having the whole alignment spot on
Posted: Thu May 17, 2007 3:45 pm
by alastairg
Nexus27 wrote:I'm on OEM stock suspension + Neuspeed RARB.
Cheers,
With you on that Lloyd. Mine is on OEM springs ARB and koni sports (just off softest) and around the 'cart tracks' edinburgh claims are roads I can take a pounding. Out on A roads/motorways all is perfect with handling spot on.
Angus when I mentioned to Doug my ARBs were getting old as yours ?should I replace...he laughed. But did mention the S4 option for a handling upgrade
Posted: Thu May 17, 2007 6:12 pm
by rs2315
Cheers,
GT500 on the S2 forum has them fitted on oe springs.
rs2315.
Posted: Mon May 19, 2008 10:01 pm
by UUUdiRS2Newcastle
Hey people, I think I have decided that I will opt for Standard BOGE shocks all round, and H&R Springs......................wait for it................. is this a good idea? Lloyd mentioned Bilstiens are really stiff shocks, so if I have H&R springs too, its gonna be a bit of a bone shaker, so im thinking that I will go for Boge Shocks, as they are easy to fit, and then Lower H&R Springs, making it a firm but not too firm ride.
Im running 18"x 8.5" Cup 1 Porsche Wheels with Pirelli PZERO NERO 225/40/18"s so its a harder ride already!
Any comments?
Posted: Tue May 20, 2008 8:43 am
by alastairg
If I was starting again I would go OEM shocks & springs. IMHO they got it right.
Posted: Tue May 20, 2008 10:03 am
by Lloyd
Fraser, fully re-freshed OEM is probably not a bad place to start, although I think your car will visually look the best when on H&R's. Have a look for photos of Sherv RS2 on s2forum. this will show you what I mean. he was the previous owner of your wheels.
I personally am seriously considering opting for bilstein at some point this year and will talking to Rob GT500 for help on the groove machining.
Posted: Tue May 20, 2008 7:03 pm
by rs2315
GT500 is running cup 1's 245 35 18 with RS2 HaR's and Bilstein sport springs.
Yep the ride is firm, and not for everyone.
But on my own car I've never been happy with to much roll on roundabouts, and to much lift on accelaration, and to much dive on braking.
I've been in GT500's car on the set up above, and it gets rid of the above.
Me thinks I'm about to copy GT500
rs2315.
