Car doesn't start anymore
Posted: Tue Apr 11, 2006 11:49 pm
Hi,
After the car was idleing too low and stalling all the time I decided to clean the MAF. I really watched out not to damage it. But now the car doesn't start anymore. Below the error codes. I never use to have codes apart from an Intermitted Engine Speed Sensor error (G28). But then I read somewhere that this is normal. Now I also know that the camshaft sensor often breaks and the car wouldn't start. Anyway, I just find it odd that the car stopped working after I cleaned the MAF. See the codes below:
7 Faults Found:
00516 - Closed Throttle (Idle) Position Switch (F60)
30-00 - Open or Short to Plus
00561 - Mixture Adaptation
15-00 - Adaptation Limit (Add) Not Reached
00537 - Lambda (Oxygen Sensor) Regulation
11-10 - Control Limit Not Reached - Intermittent
13-10 - Adaptation Limit (Mul) Not Reached - Intermittent
00533 - Idle Speed Regulation
10-10 - Adaptation Limit Not Reached - Intermittent
00515 - Camshaft Position (Hall) Sensor (G40)
00513 - Engine Speed Sensor (G28)
03-00 - No Signal
Well, after looking at these errors I think its more likely that the low ideling/stalling is due to broken Throttle Position switch and not the MAF.
And the car not starting is more likely due to the camsensor, right ?
Anyway, I don't wanna shoot out an buy a MAF, Camsensor and Thottle switch.
What is the best order ... or how can I check those bits ?
Also on my RS4 I can drive with the MAF unplugged and the ECU is clever enough to run in speed density mode. Is this the same on the RS2 ?
But then, correct me if I'm wrong, Speed Density relies on the throttle position, which in my case doesn't seem to work either. ;-(
Any help is really appreciated!
Cheers,
Dave
7 Faults Found:
03-00 - No Signal
Cheers,
Dave
