rs2 brakes and turbo problems
Posted: Fri Oct 28, 2005 4:46 pm
by stu_sclater
Hi,I've just imported a mint(or so i thought)black rs2 full leather and 70k miles on the clock.The problem is the disc's feel as though they are warped,anyone know where i can get some new ones with out costing me to much.And also there seems to be a problem with the turbo,the boost does not start building till 3500 and only really gets going at about 5000,any ideas on these problems would be greatly apprieciated.Other than that the cars great.Cheers for your help........
RE: rs2 brakes and turbo problems
Posted: Fri Oct 28, 2005 5:53 pm
by robo
You can get cheap discs from here if your car has standard brakes.
http://www.eurocarparts.com/
Re: rs2 brakes and turbo problems
Posted: Fri Oct 28, 2005 8:02 pm
by AAH!
You may have a boost leak or you may have a bigger non-original turbo that spools up later.
Do a search for boost leaks on this forum and on www.s2forum.com
Getting brake parts from Porsche or a discount Porsche parts shop such as www.type-911.co.uk or www.design911.co.uk are often cheaper than Audi.
Have a look at this previously posted list of Porsche brake parts that are used (in theory) on a RS2. I did not compile this list so cannot guarantee its accuracy.
Angus
RE: Re: rs2 brakes and turbo problems
Posted: Fri Oct 28, 2005 8:39 pm
by DavidT
That attachment contains a virus called W97M.Thus.gen according to Norton AntiVirus
Re: RE: Re: rs2 brakes and turbo problems
Posted: Fri Oct 28, 2005 9:26 pm
by AAH!
DavidT wrote:That attachment contains a virus called W97M.Thus.gen according to Norton AntiVirus
How horrible. Sorry about that, don't know how that happened. I made the zip file from a MS word document as this site wouldn't let me attach a word doc.
I cant seem to delete the attached file.
Try here instead:
http://www.s2forum.com/forum/showthread.php?t=9177
Sorry.... Angus
RE: Re: RE: Re: rs2 brakes and turbo problems
Posted: Fri Oct 28, 2005 11:07 pm
by DavidT
No worries mate.
I know you didn't do it on purpose but I didn't want you to pass it on either.
David
Posted: Sat Oct 29, 2005 6:58 am
by VaudiGR
on the turbo issue...i can understand that the turbo starts to kick in on 3000rpm,but then it only kicks in at 22psi around 3700rpm.If it gradually goes up could this mean that i need a turbo service?
i am going to have one with my timing belt change in about 10000km but i was just wondering from the syptoms....
in general are there any symptoms of a turbo service requirement?
Posted: Sat Oct 29, 2005 8:07 am
by stu_sclater
Thanks for your help guys,I'll try the links you suggested.Cheers.....
Posted: Wed Jan 25, 2006 9:49 am
by PhilT
The file has been cleaned.
If you have downloaded it and are unsure that your machine is clean, then try this http://www3.ca.com/securityadvisor/virusinfo/scan.aspx
Posted: Fri Mar 31, 2006 8:58 pm
by Hansen
I had the same problems with my brakes. New discs and "homefixed" calipers.With Porsche logo... The result was not so bad:)
Posted: Fri Mar 31, 2006 8:59 pm
by Hansen
calipers in the kitchen..
