under boosting problems....
Posted: Wed Sep 21, 2005 2:11 pm
Had my RS2 on the track at castle Combe for a few laps when suddenly noticed from the boost gauge that the car was under boosting.
My car has been mapped by Mihnea and produced 20 psi upto 4000 rpm with boost then increasing to 25 psi thereafter to redline. It now will not boost past 10 psi.
Have had the codes taken from the ECU and there was some minor stuff. Anyway, checked all sensors and reset the ECU but the result is the same. No more codes are appearing on the ECU.
Have checked all hoses (10 times!) and pressure tested the intake system. It holds pressure well so no big leaks.
Only thing not yet changed or tested is the WGFV (I have a spare one to try on it) and the wastegate diaphagm which I know can split.
Other than that, has anyone got any ideas as I am running out of inspiration!!!
