rs2 hybrid
2.2 I5 20v turbo - 315 bhp
nige
rs2 hybrid
Post by nige » Sat Jun 25, 2005 1:08 pm
hi there another new bod to the forum. i have a blue rhd 1996 with 62000 on the clock. I am after some facts and figures with reference to a hybrid turbo if there is anyone out there please give us a shout. tvm nige
AAH!
RE: rs2 hybrid
Post by AAH! » Sat Jun 25, 2005 1:31 pm
I have a Turbo Dynamics MD147 Hybrid kkk26/27 Turbo which a number of other people here also seem to have.
Although it gives me a lot of top end oomph it only kicks in at around 3600rpm so there is a bit of waiting around for something to happen, but once it does kick in it is great and just keeps pulling. The 7A cams may also add to this effect as well.
When my car was recently remapped by Mihnea at MRC he expressed a preference for the standard RS2 turbo over my one (he had already done a number of S2'S/RS2's with the MD147 turbo) as it was much better suited to the car as the turbo kicked in much earlier and allowed for better bottom end performance and when combined with his custom mapping he felt he could get better allround performance than with mine. (I'm sure Mihnea will correct me if I am wrong)
HTH
Angus
RS2 +
nige
RE: rs2 hybrid
Post by nige » Sat Jun 25, 2005 2:48 pm
thanks what output does the setup that your runing give you? I,m looking for a quicker response time something like the turbo cutting in at 2500 have you any numbers for mrc? nige
robo
RE: rs2 hybrid
Post by robo » Sat Jun 25, 2005 8:45 pm
just cant get enough of it
AAH!
RE: rs2 hybrid
Post by AAH! » Sat Jun 25, 2005 9:56 pm
Check this thread out for standard and non standard RS2 remaped dynoplots and output figures. Also includes mine.
http://www.rs246.com/index.php?name=PNp ... ic&t=48851
Also check out the latter part of this thread for imediate post map reactions:
http://www.rs246.com/index.php?name=PNp ... ic&t=48661
Here is MRC's UK site:
http://www.mrctuning.com
Doug, Lee and Mihnea (aka MRC) are sometimes found here as well as on the s2forum:
http://www.s2forum.com
RS2 +
Greg_S
RE: rs2 hybrid
Post by Greg_S » Mon Jun 27, 2005 9:11 am
Nige,
It is probably worth you looking in the direction of the Garret T0?? series turbo's or a GT garret turbo since the spool up very quickly and ealier than the 3600. It all depends how you drive the car really. Its quite nice not havin the turbo kick in properly until 3600 revs because you can cruise along at a more sedate pace around town easily and one down shift and your off.
Bullshit baffles brains
nige
RE: rs2 hybrid
Post by nige » Mon Jun 27, 2005 5:43 pm
Im quite a sedate driver really! Its the 0 - 60 time that I want to get down. the top end 100+ I'm happy with. if the remapping by MRC helps with that fine Im trying to get the right information before I decide. Ive also heard that nitro can help with the cooling do you know if thats correct. The more info the better. tvm
Greg_S
RE: rs2 hybrid
Post by Greg_S » Tue Jun 28, 2005 10:49 am
0-60 a hybrid would help with since the RS2 doesnt have quite as much top end, NOS can help too if its setup right. Havent any personal experience of that though.
there is lots that you can do, on yours just changing the exhaust cam will give you a bit more top end with a remap. All a question of how much cash you have to spend
nige
Post by nige » Tue Jun 28, 2005 7:37 pm
I wouldnt say dosh is a problem as I wear the trousers but the one who chooses the colour might get a bit miffed if I spend more than 5k just down to the fact that I ve just had an entertainment system fitted; obviously though that was for the kids! I'm going to speak to Mrc this week as it seems the feedback that im getting is that they know there stuff.
Nige_RS4
Post by Nige_RS4 » Tue Jun 28, 2005 7:47 pm
Even the S4 with it's twin turbos will struggle to delivery masses of boost at 2500 rpm.
IMHO you've got unrealistic expectations unless you drop down a turbo size.
Nige (another one!)
Greg_S
Post by Greg_S » Wed Jun 29, 2005 10:27 am
MRC are v experienced. my car has been mapped several times by them and im very happy with the work done. My car and Angus's are almost identical apart from the cams and he has about 15-25hp more on his.
Speak to turbo dynamics about their hybrid turbos since they have a good range for the S2/RS2
DamoM
Re: RE: rs2 hybrid
Post by DamoM » Tue Jul 12, 2005 3:28 am
AAH! wrote:I have a Turbo Dynamics MD147 Hybrid kkk26/27 Turbo which a number of other people here also seem to have.
HTH
Angus
What about this one:
http://www.034efi.com/product_info.php? ... cts_id=196
This is a new turbo and www.034efi.com have had magnificent results with it, especially with RS2s. It offers quicker spool up but better flow than the RS2 unit so everyone is a winner! They are selling like hot cakes apparently!
I am actually buying one for my 10v UR quattro (RS2 efi etc) and 034efi.com have had a 10v, with their injection system, running at almost 500 BHP (they were testing the flow capabilities!) which is incredible, even compared to the RS2 unit.
I too have a garret/kkk hybrid on my RS2 which provided some surging at lower revs when the boost came on which Mihnea had to dial out by reducing boost to 18psi until about 4000 revs when I get a full 24/25 psi. He said that the unit was less efficient lower down the rev range than the RS2 unit (because of the potential for surging) but better at higher revs. However, because it is a ball bearing unit the turbo will produce full boost by 3000 in 3rd to 6th gears - which is better than the standard RS2!
I am going to see how it goes on my 10v and if it is a good unit then I will definitely fit one to my RS2!
Turbo Dynamics are still scratching their heads to see if they can make one. If not then I will buy straight from the US and send any old turbo out to them first so that it classes as an exchange (reduced duty).
Greg_S
RE: Re: RE: rs2 hybrid
Post by Greg_S » Tue Jul 12, 2005 9:48 am
keep us posted on how you get on with this. As with all turbos there is always gonna be a compromise somewhere.
DamoM
Re: RE: Re: RE: rs2 hybrid
Post by DamoM » Tue Jul 12, 2005 10:02 am
james_dj wrote:keep us posted on how you get on with this. As with all turbos there is always gonna be a compromise somewhere.
Am getting my RS2 dynoed today. Was 335bhp before Mihnea remap so keen to see how much improvement there is. Same dyno and operator as before so will be a direct comparison......
Greg_S
RE: Re: RE: Re: RE: rs2 hybrid
Post by Greg_S » Tue Jul 12, 2005 11:37 am
what spec is it for 335hp?
Users browsing this forum: No registered users and 191 guests
