Idling problems
Posted: Tue Jun 07, 2005 10:17 am
by DamoM
looking for a bit of help with an ongoing problem with my '95 RHD car.
Had starting stalling regularly and hunts when trying to idle.
Have swapped the idle control valve with my 20v UR but that makes no difference.
Have checked all of the pipes for leaks and checked that all connections are secure.
HELP..........!!
RE: Idling problems
Posted: Tue Jun 07, 2005 11:40 am
by alastairg
Air leak
MAF dirty or done
Sparks
RE: Idling problems
Posted: Tue Jun 07, 2005 2:34 pm
by DamoM
alastairg wrote:Air leak
MAF dirty or done
Sparks
checked for air leaks. swapped the MAF with my UR quattro one (RS2 spec) and no change. New plugs fitted but no change. Interestingly the car idles absolutely fine with the MAF disconnected (but obviously will not drive under boost in this guise!). Any ideas?
RE: Idling problems
Posted: Tue Jun 07, 2005 5:47 pm
by maRS2
Did you check altitude ambient presure F96 sensor
RE: Idling problems
Posted: Tue Jun 07, 2005 5:56 pm
by DamoM
maRS2 wrote:Did you check altitude ambient presure F96 sensor
No I didn't...! What is it, where is it and how do I check it!
RE: Idling problems
Posted: Tue Jun 07, 2005 7:01 pm
by GlynRS2
Posted: Thu Jun 16, 2005 6:41 pm
by DamoM
replaced dump valve - problem solved!!!
Thanks guys.
Posted: Thu Jun 16, 2005 7:49 pm
by alastairg
was the diaphragm split ?
Posted: Thu Jun 16, 2005 8:21 pm
by GlynRS2
Which dump valve did you use?
I replaced mine with a Forge 007. Others have used the S3 one or of course you can always stick with the OE RS2 one.
Posted: Thu Jun 16, 2005 9:17 pm
by DamoM
It was a piston type one and was leaking under a vacuun test. I replaced it with the S3 item which by all accounts is stronger than the OE RS2 one..?
Posted: Fri Jun 17, 2005 9:42 am
by alastairg
Excellent choice. Standard diaphragm type are quicker reacting than piston but need to be considered service items.
Posted: Wed Aug 10, 2005 5:02 pm
by VaudiGR
what is a dump valve and where is it located in the engine bay?i need to know cause i may be having the same idle problems
thanks!
