Spark plug intervals
Posted: Mon Jan 24, 2005 12:15 pm
by alastairg
Standard RS2
3 years/40k or more often. What is the collected experience here ?
Oh and if I remap. Change more often ????
RE: Spark plug intervals
Posted: Mon Jan 24, 2005 9:36 pm
by GlynRS2
I manage to get a set at GTI International for £5 each.
The car had only done about 6,000 miles on the previous set, but felt a little sharper when they were first replaced.
Didn't throw the old ones away as they were so new, but if can get the plugs at that price again I will probably change them every year.
Probably completely unecessary though.
Posted: Mon Jan 24, 2005 9:44 pm
by scillyisles
I've done 48K in mine since new (1995) and I've changed the spark plugs four times in 10 years. When you change them you immediately notice the difference with the engine running smoother and pulling much better. If you can't get them as cheap as Glyn suggests then I seem to recall that german and swedish stock them for not much more.
Posted: Tue Jan 25, 2005 10:43 am
by hiltron
When you accelerate full throttle under load ( Uphill.) if the car has a slight splutter at top end of revs. 5-6000rpm. Time to change plugs.
Posted: Tue Jan 25, 2005 5:31 pm
by alastairg
No splutter
Posted: Tue Jan 25, 2005 9:27 pm
by Doug_S2
I would replace them once a year - every second service. Check they are torqued correctly - they are famous for coming loose.
Posted: Fri Jan 28, 2005 11:07 am
by alastairg
Done and as scillyisles says the car is sharper. Will go to annual changes
