Anyone with VAG-COM in London area?
Posted: Mon Jan 17, 2005 2:57 am
I'm trying to get to the bottom of a low boost problem (0.5bar max) as discribed in this thread I started on the S2 Forum:
http://www.s2forum.com/forum/showthread ... #post72877
So far I have changed the hoses to samco's, fitted a new forge dv, fitted a new WGFV, tried unplugging the MFTS, checked the TPS & CTP, pulled Blink codes (1111 came up: Engine Control Module Malfunctioning - Poor ground connection. Also can suggest that the ECU has been chipped/mapped/tampered with), output tested the sensors. New hall & speed sensors fitted 5 months ago and poor earth connection rectified (i was told). Pressure test kit, new Lambda & new MFTS in the post.
So far, no luck.
Basically it looks like the next stage of the process will be pulling the codes with VAG-COM as I need more detailed info than blink codes can provide.
Can anyone help with VAG-COM in the London area?
All the best....Angus
So far, no luck.
