RS2 Wheels (again)
Posted: Wed Oct 27, 2004 11:21 pm
by dave993cars
Hi
I have just joined the forum, I have an RS2 1995 (RHD) after reading some recenent topics I have descovered that I have new 245/40/17 SP Dunlop tyres, I purchased the car in exeter in September and have driven 1000 miles since (I live in Scotland). my question is I have Porsche GT3 sport design wheels and tyres 7.5j 225/40/18 and 9j 265/35/18 in my garage will they fit the RS2, it is a long way to take the Dunlop tyres back. Can anyone help.
Dave S
Posted: Thu Oct 28, 2004 9:26 pm
by Rob20vurq
Hi Dave, welcome.
The answers to your problem are difficult, do you know the off set of your 18" wheels?, You will probably need to have the wheel centers machined out (RS2 has big registers on the hub for wheel location- 73.1mm)
The 7.5 wheels will fit if you do the above providing the offset is ok.
9" is probably too wide,I have 8 x 17 et 52s on my car, they are very close to the edge of the bodywork.No touching though!
Take your new tyres back or sell me them!!! or get some 8x17 cup 1s.
Rob.
RS2 Wheels (again)
Posted: Thu Oct 28, 2004 10:14 pm
by dave993cars
Hi
Thanks for the reply, the 9j is 52 ET and the 7.5j is 50 ET
I had a similar problem when I fitted these wheels to my 944 ie the bearing hub would not allow the wheel to be fitted, to solve the problem I fitted a 7mm spacer.
I have also been offered a swap for my 9j for 7.5j so I would have 7.5j all round, do you think this would be OK.
Many Thanks
Dave S
Posted: Fri Oct 29, 2004 10:21 am
by Rob20vurq
Dave, not good!!!!! the wheel needs to register....did the spacers have registers????
7.5 x 18 et 50 should fit nicley.
Get the wheel centers machined out! it will only cost £10.00 a wheel.
Hope this helps,
Rob
RS2 Wheels (again)
Posted: Fri Oct 29, 2004 8:31 pm
by dave993cars
Rob
Thanks for the advice, but excuse my ignorance what is the register on the spacers? the 7mm I fitted to the 944 were from a porsche specilist and they fitted with no problem, the only reason I changed bact to my 17s was the rear was tramlining a bit, pleased that the 7.5j is OK
Regards
Dave S
Posted: Sat Oct 30, 2004 1:48 am
by Rob20vurq
Register is the sticky out part of the hub or spacer that "registers" the centre of the wheel to the hub or spacer ie does not let the wheel only locate using the wheel studs.
