RS2 Powerflex Bushes
Posted: Thu Sep 23, 2004 2:52 am
by Fourrings
We had this posted up on Audifans.net (I'm site admin on there :wink: ) by Matt from powerflex,,,,so I thought I'd post it here too,,,,,this is a copy and paste of his post,,,,,,,,,
We have been getting loads of phone calls on new bushes so we have finally finished bushes for the Audi RS2.
Please find below all the NEW bushes we do,,,,
FRONT WISHBONE
BUSH PFF3-101* 12.95
4 PER CAR(EACH) For steel arm
FRONT WISHBONE
BUSH PFF3-102* 13.95
4 PER CAR(EACH) For alloy arm
FRONT ANTI ROLL BAR
PFF3-103-24**
PFF3-103-26** 12.95
PFF3-103-27**
FRONT OUTER ROLL
BAR MOUNT LOWER
PFF3-104 COUPE, 9.95
2 PER CAR (EACH)
FRONT OUTER ROLL
BAR MOUNT LOWER
PFF3-105 9.95
2 PER CAR (EACH)
FRONT ENGINE
STOP BUFFER ***
PFF3-199 9.95
1 PER CAR (EACH)
REAR LOWER
ARM FRONT BUSH**
PFR3-205 12.95
2 PER CAR (EACH)
REAR LOWER
ARM REAR BUSH**
PFR3-206 15.95
2 PER CAR (EACH)
REAR UPPER ARM
OUTER BUSH
PFR3-208 12.95
2 PER CAR (EACH)
REAR UPPER ARM
INNER BUSH
PFR3-209 14.95
4 PER CAR (EACH)
REAR ANTI ROLL
PFR3-511-12 12mm
BAR BUSH PFR3-511-15 12.95 15mm
PFR3-511-16 16mm
Please see website for details www.powerflex.co.uk
Or contact one of our many distributors.....
We as a company also believe that if there're any products we do not do or any that are a problem please contact us, we are looking to increase our range every day..
If anyone wants an exel file with further details,,,,,PM me
Posted: Mon Oct 25, 2004 7:48 pm
by niko
Anyone know what size anti roll bars the early 1994 model rs2 had?
Niko
Posted: Thu Oct 28, 2004 6:26 pm
by Greg_S
I have a spare set of PFF3-101 (4 bushes) sitting in front of me, they were fitted for a short time but work fine.
pm me if anyone wants to buy them, im open to offers
Greg
Posted: Fri Oct 29, 2004 7:39 am
by hiltron
Why were they only used for a short time? Are the originals better? I have just bought a sot of powerflex and can't wait to put them in and try them out.
Posted: Sat Oct 30, 2004 12:04 am
by AAH!
look forward to some feedback on the powerflex bushes, as it about time mine are renewed along with the top mounts and shocks.
Angus
Posted: Sun Oct 31, 2004 3:40 pm
by niko
I've gottenm reports that on the ride on the rs2 at least would become noisier and harsher. But its hard to quantufu by how much, so I think I'm just going to replace them with OE parts.
Niko
Posted: Tue Nov 02, 2004 9:24 am
by Greg_S
hiltron wrote:Why were they only used for a short time? Are the originals better? I have just bought a sot of powerflex and can't wait to put them in and try them out.
I have powerflex ones in there again now and they are a big improvement, the first set I put in i had problems with them squeaking. Afterwards I realised they were probably just a little tight and that is what caused the problem. :oops: so left with a spare set now.
Greg
Posted: Sun Nov 07, 2004 12:26 am
by s2driver
I destroyed my Powerflex bushes in a few months (but then I can pull in excess of 1.5g in deceleration with my new brake setup). I have pressed wishbones (as opposed to cast) and the steel ends up digigng into the bush exacerbating its demise. Superflex do a much better bush for the pressed wishbone as it has a formed sleeve to prevent the wishbone digging into the bush. I have only seen pictures of the Superflex bush but the design looks as though it would solve the problems I had. Not sure how easy sourcing is for Superflex becuase they are an Australian firm with only 1 UK agent.
NVH (Noise Vibration Harshness) on an RS2 will be unchanged from standard with any Poly bush. Don't forget NIKO, you have another set of compliant bushes between the subframe and the chassis. THe only purpose of the subframe is to support the front wishbones. Polyeurethane bushes will last longer than standard without any noticable ride alteration. In fact you'll get sharper responses.
Posted: Mon Nov 08, 2004 4:53 pm
by Greg_S
what about the solid subframe bushes people are fitting nowadays?
I spoke to a guy from superflex a while back and can source the bushes quite easily.
Greg
Posted: Mon Nov 08, 2004 4:54 pm
by Greg_S
Greg
Posted: Mon Nov 08, 2004 8:00 pm
by s2driver
Not too sure Greg. One nice feature of the B4 chassis is the fact that we have a set of bushes between the wishbones and the subframe and another set between the subframe and the monocoque. Firming up on one set of bushes hardly affects ride but putting solid ally subframe bushes in will probably make things quite a bit harder on amny surfaces. I am sure responses would be greatly improved especially on an older car with tired bushes. The main reason originally for two sets of bushes between wishbone and monocoque is for refinement but you also get a reduction in peak forces on the structure on most maneouvers.
Solid subframe bushes and poly wishbone bushes should be OK for road use but I wouldn't do it on my car. I live in rural Wales and my suspension takes a hell of a hammering on the lanes. The last think I want is cracks in the bodywork just for the sake of a bit of extra feedback on turn-in. When I am sliding sideways on a road of fresh cow pats (like I did 3 times today!) the ally bushes aren't going to make any difference at all! If I still lived in Guildford I would definately make the change as the roads there are a bit better (although proportional to the wealth of its residence, the least well maintained!!).
Lee
