Handbrakes
Posted: Wed Aug 25, 2004 2:00 am
Having read Pete RS2's post in the "how many rs2 owners do we have here?" thread and the following couple of responces on handbrakes and also as my MOT is coming up soon and the handbrake will needless to say need adjusting, I thought a "Handbrake" thread might throw up a few tried and tested fixes even if they are comparitivley short lived.
The only thing I can offer up is that I seem to remember something about tightening up the handbrake on the calliper rather than via the handbrake cable, but I can't remember the exact details or procedure.
All the best...Angus
PS I dug up this handbrake fix (?) on the yahoo rs2 list, courtesy of Jani and before that Joern.
http://autos.groups.yahoo.com/group/RS2 ... ssage/2073
"I had the decribed operation (SEE BELOW) done to mine about 11 months ago. Surprisingly for me, it did come good, and has stayed that way, through one winter even. The key is drilling the dirt removing vane.
The power isn't good, I can't lock wheels on tarmac, but it holds the car stationary on small slopes, and passes MOT. Getting a powerful hand brake with RS2's parts is unlikely I was told, the design is such that getting force through is impossible.
One more tip: if you are having the rears done, book one extra day, and have the old hand brake shoes recoated -you'll save about 100€.
Regards, Jani "
http://autos.groups.yahoo.com/group/RS2 ... ssage/1035
Date: Wed Nov 6, 2002 2:50 pm
Subject: FW: instructions to make the ebrake work...
Hi,
as some of you may also have trouble with the handbrake / ebrake of the RS2, thought I'd share this advice, how to make the RS2 ebrake functional, and what needs attention for it to work properly. I got the advice from Joern Amundsen (current owner of the UrS4 MTM RS, pics of the monster in www.audituning.com), after I had complained on the s-car list how crappy the RS2 handbrake is. According to him it can be made better than normal Audi handbrake, haven't yet tried it.
Thanks to Joern!
Regards,
Jani
Hello Jani!
I assume you have used rear rotors on your RS2, and what you have to do is the following:
1) Have a good brakerepair shop machine the surface of the rotor where the e-brake shoes contact(the 180mm OD inner ring)
2) Since this will give you a different diameter you also have to grind off
the e-brake shoes in a special grinder to get the EXACT same radius as
the machined rotor. Any good brake shop should have this machine. This is the critical part since you ned contactarea on the whole shoe(four of them)
3) Grind a 3mm slot on the calipercarrier pointing from the rotor
center and directly to the ground. The slot is on the area where the shoes slide, meaning that when you have it all installed exept the rotors, you can see the idea. Any water,sludge etc can evacuate from the area. Can you figure that?
4) When installing the pads on the carrier plate, make sure you grease
the expandinglever and the cable hook up (the 6 mm pin). With the shoes
resting at the top on the "holding lip"(you might end up slacking the wires to accomodate this), adjust the bottom of the shoes so you can barely turn the rotor by hand. It might require the rotors to get off several times before you get it right.
5) Then adjust the wires if neccesary.
Best reg Joern
Regards, Jani "
Hi,
Thanks to Joern!
Regards,
Jani
Hello Jani!
Best reg Joern
