Some info for you
Posted: Tue Jul 13, 2004 11:55 am
Hi Gents.
Been busy getting my car as near perfik as I can. Got a standard LHD and have used it nearly everyday for three years now.
I started with the brakes. I wanted to replace the discs all round and new pads obviously. Audi as you know are a rip off! over £ 200 per rear disc.
So i tried a Porsche dealer. A very helpful bloke came up with the following. The RS2 actually has fitted 928 p/n P928.351.043.60 & P928.351.044.60 discs on the front (£80.85 each) with 993 pads and calipers pads p/n P993.351.939.01 £81.24 / set.
The rear discs are no longer made by Porsche. These were p/n P951.351.041.02. I bought these from Euro car parts for just over £40.00 each and they are working fine with Porsche pads P964.351.939.03 £41.73.
Hope This is helpful.
Tyres. I here mubblings of how great PZero 245,s are. Well here is a story for you. Soon after I bought the car, I had to try it out to the max. I got to about 145 when the front RH tyre departed company with the car. I'll be honest and say the fact that I am still here is just luck and nothing to do with being able to drive a car with three wheels. The tyres were nearly new 245 40 17 Pzeros. The only 245 tyre that will fit on the Porsche 7 inch rims, despite what is said, is the now defunked SP from Dunlop. This had reinforced sidewalls and is actually about 4-5 mm narrower than a 225 tyre and was built soley for the RS2. There are two problems with fitting 245 40 17 replacements. The first is that the sidewall chaffes on the suspension arm and causes a blow out as most people have found out. The second is that by squeesing a 245 tyre on to the 7 inch rim the sidewall is stressed and eventually cracksl the tyre structure at the radius between the sidewall and the tread area. this is what happened to mine. I am running 225 45 17 Y rated Avons that are just fine. these are the same width and roll radius of the original Dunlops, as are any other make of this size. Perelli actually list the P zero Rosso 245,40 17 Y as the correct tyre for the car. I promise you it isn't.
