Apgrade discs?
Posted: Sat Jul 10, 2004 7:57 pm
by robo
Hello I've tryed to do my front brakes upgrade today, got all bits ( 993 turbo calipers, 993 322x32mm discs and pads), the only problem i had i think was the discs they not deep nuf, has any one done upgrade them selfs, do you know corect porsche part number for front discs 322 x 32 mm?
Can any one help plz.
Thanx.
Posted: Sat Jul 17, 2004 12:06 pm
by Jani
You need discs from 928GT or GTS with deeper disc hat. That should fit. Plus the caliper air removal valves need to face up, I think 911 calipers they face down. Can be switched.
Posted: Sat Jul 17, 2004 1:32 pm
by robo
I have switched valves they facing up now but discs are of 993 turbo and as you set hat is not deep nuf.
Thanx Jani for this Very Very important info,
Thanx again m8
Posted: Sun Jul 18, 2004 11:02 pm
by odysseyireland
I am looking at an RS2 that has had brake discs changed to cross-drilled items from a 944 Turbo which current owner says work well (it was a previous owner that changed them), roughly same size as std RS2 discs but drilled.
Are these similar to the 928GT ones mentioned above?
Posted: Sun Jul 18, 2004 11:14 pm
by robo
I hope not , I need 928gt to be 322mm, 944t and rs2 are 304mm.
Posted: Mon Jul 19, 2004 9:28 am
by odysseyireland
so the 944 Turbo ones are a good enough replacement, same size but cross-drilled. Not as good as the larger discs obviously, but a little better than standard.
Posted: Tue Jul 20, 2004 8:27 am
by Jani
I'm not sure whether 928GT had 322mm brakes, the GTS I'm quite sure did have these -with the right offset for RS2
Posted: Tue Jul 20, 2004 9:09 pm
by robo
928 GT is 304mm 928 GTS 322mm but they dont do them cross-drilled.
Finaly i have finished the upgrade, feels GR8 , 993 turbo big reds with pads and 928 gts 322mm discs, not recomended to DIY due to no part numbers.
