Fuel pump noise?
Posted: Sun Mar 28, 2004 11:51 am
by alastairg
UK car FASH 76k new to me as of yesterday(from S2 so familiar with basics)
Transient noise from fuel pump on start up Views welcome
Posted: Sun Mar 28, 2004 12:10 pm
by s2driver
A whining noise is probably either the pump giving up or a clogged filter causing it to work harder. I am surprised that yours is making a noise at only 76k. Mine gives an occasional whine now and again but its done 145k+ and I recently replaced my filter which cured some dangerous lean running too. If you are going for bigger power you can replace the sock pump with a Bosch Motorsport item which is good for well over 500horses on the I5. Since the motorsport pump is larger than the existing in-tank unit, you need a few additional parts in order to fit it. Total cost for the Bosch pump and associated bits is around 200quid.
Lee
"Rattle" on start-up?
Posted: Sun Mar 28, 2004 3:22 pm
by RS2_Russ
Is the noise a bit of a sort of "rattle"-like noise? Mine's been doing that for 2 years now and occasionally whines a bit, too. Changed filter to no avail. Am told it's slowly on the way out, at 115k miles, but then it's been doing it for 2 years now and still goes just fine.... :D
Posted: Sun Mar 28, 2004 8:51 pm
by robo
I had the same problem, after new pump the noise is still there, so must be the fuel filter,try to change that what a f*** bastard, would not come out.
Posted: Sun Mar 28, 2004 9:32 pm
by s2driver
You need to drop the tank to change the filter on the 80Avant Quattro chasis. It's a PITA. I cut the plastic bracket (which is welded to the plastic tank) and fitted a larger S2 ABY Coupe filter to mine. Apart from some petrol in my eye, I did the job in about 30minutes.
Posted: Sun Mar 28, 2004 10:34 pm
by DAVIDP20V
i have the same noise, i think !
turn the key, after start up the car idles, then i begin to hear what i think is the pump going flat out, then the noise disapears
seems like its getting up to pressure then levelling out
mine has been like this for years ! never caused a prob :thumbs:
Posted: Mon Mar 29, 2004 10:15 am
by alastairg
Thanks to all
Had similar problem with S2 resolved by replacement. HOWEVER since post all has gone quiet!!
It may be the increased noise courtesy of the exhaust c/w S2 that fooled me.
Posted: Fri Apr 30, 2004 4:58 pm
by alastairg
First service in my ownership great local indep Audi specialist Autowerks Edinburgh SOLVED pump noise Change the fuel filter!!
Posted: Fri Apr 30, 2004 5:43 pm
by DAVIDP20V
ohhhhh no, i dont want to change my filter, take ages (drop tank etc)
what did they charge you to change it ?
Posted: Fri Apr 30, 2004 7:28 pm
by alastairg
Difficult as lots done
Posted: Fri Apr 30, 2004 7:47 pm
by DAVIDP20V
i purchased a fuel filter with the intention of changing, but after hearing they are a right pig on the avants over on s2 forum,
i have decided to delay the job .....
....for about 8 months now !
Posted: Fri Apr 30, 2004 10:24 pm
by Greg_S
its def worth doing, a few of the owners did it and it solved a few running problems. obviously previous owners had the same thoughts as you when it came to be serviced. lol
Posted: Sat May 01, 2004 12:15 am
by DAVIDP20V
james whats you address i'll make the tea and you can do the filter !
easy life :bigblink:
