which brake fluid DOD=?
Posted: Sun Dec 21, 2003 10:21 pm
by timucin
what number DOT has to be used on rs2?
thnx
Re: which brake fluid DOD=?
Posted: Tue Dec 23, 2003 12:25 am
by NIKOLAS
Hi Timusin try using MOTUL 5.1. Its the best. IF you can't find motul make sure you use dot 5.1 which is much better than any dtb 4 brake fluid. 5.1 means it can withstand far more higher temps than dot 4 scale fluid. I had serious problems with my motorbike too ( a BMW 1150 GS) due to brake fluoid overheaat and dot 5.1 saved he problem.
Posted: Tue Dec 23, 2003 3:00 am
by timucin
OK THNX
Posted: Tue Dec 23, 2003 10:52 am
by wazza
Except Castrol SRF [img]images/graemlins/thumb.gif[/img]
Posted: Tue Dec 23, 2003 11:25 am
by Cobstar
Was DOT 4.0 the best available when the RS2 was first produced? The brake fluid container on mine has "Only Use DOT 4.0" written on it.
Posted: Wed Dec 24, 2003 2:56 pm
by NIKOLAS
Some info [img]images/graemlins/smirk.gif[/img]
DOT 5.1 BRAKE FLUID
Non-silicone based, long life and 100% synthetic, DOT 5.1 BRAKE FLUID conforms to the highest standards in brake fluid performance.
DOT 5.1 is specially designed for Anti-Locking Brake Systems (ABS). With a high dry boiling point of 270°C and a high wet boiling point of 185°C,
DOT 5.1 delivers the best brake performance.
Whereas DOT 4 :Glycol-based and 100% synthetic, DOT 4 BRAKE FLUID enables an effective brake even under extreme conditions. The high dry boiling point is
245°C and the high wet boiling point is 158°C. Suitable for all types of hydraulic actuated-brake and clutch systems.
Posted: Wed Dec 24, 2003 4:35 pm
by GlynRS2
DOT 5.1 certainly gives better performance. I have used ATE Super Blue Racing brake fluid for the past 5 years of so in my Corrado. You certainly notice that the brake pedal remains firmer & there is less fade on repeated hard use. Essential for track days etc. The blue brake fluid also looks good in the resevoir, a good match for the coolant resevoir.
So the one I use is blue and makes it firmer & last longer [img]images/graemlins/wink.gif[/img]
Posted: Wed Dec 24, 2003 5:44 pm
by wazza
DOT 5.1 BRAKE FLUID
Castrol SRF is a DOT4 fluid, but look at the numbers:
Dry BP = 310 degrees [img]images/graemlins/smile.gif[/img]
Wet BP = 270 degrees [img]images/graemlins/laugh.gif[/img]
Name a DOT5.1 fluid that will keep up with that?
Posted: Fri Dec 26, 2003 8:02 pm
by GlynRS2
I have just checked on the tin and ATE Super Blue Racing is actually a DOT 4 brake fluid, but still not your normal brake fluid. See link below:
http://www.empire1.net/racing/neonracer ... luid.shtml
Posted: Sat Dec 27, 2003 12:39 am
by timucin
thnx for help
i almost became a fluid expert [img]images/graemlins/smile.gif[/img]
Posted: Sat Dec 27, 2003 1:28 am
by wazza
thnx for help
I thnk I became a fluid expert tonite [img]images/graemlins/062802drink_prv.gif[/img]
Posted: Sat Dec 27, 2003 2:02 am
by timucin
LOL!!!
[img]images/graemlins/thumbs.gif[/img]
