Hi All
Hope you can help, I have found two small oil leaks, one is at the bottom of the oil cooler on the offside front, the cooler is feed air from the inlet in the bumper and the undrside of the cooler is damp. The second leak is on the back of the rocker cover leaking oil on to the down pipe of the exhaust, how easy is it to change the cooler and replace the rocker cover gasket.
Thanks in anticipation.
Dave S
oil leaks
RE: oil leaks
i think the rocker gasket is no big deal,and i would also think the cooler wont be hard either.I think the main gasket(middle one)is the tougher where you have to take the whole engine apart..)
