Hi.
I'm looking for part numbers for a TB and Waterpump kit for a 94 RS2.
Will the following ones do?
054109119H TIMING BELT
034903137B RIBBED BELT
054121004AX WATER PUMP
Any help is much appreciated.
Audi RS2 Timing Belt and Waterpump Part numbers
Re: Audi RS2 Timing Belt and Waterpump Part numbers
034 109 119 C toothed belt
034 121 004 BX coolant pump with sealing ring
The belt has an extra ' tooth ' as does the water pump .They are RS2 specific. Both available from Audi tradition. Last time I checked water pump was £300.00 + and belt £80.00 . Tensioner/idler pulley is extra .Some people have managed to remove the water pump pulley and press it onto a ABY engine code water pump which is waaaaay cheaper .
