Idling problems
Idling problems
looking for a bit of help with an ongoing problem with my '95 RHD car.
Had starting stalling regularly and hunts when trying to idle.
Have swapped the idle control valve with my 20v UR but that makes no difference.
Have checked all of the pipes for leaks and checked that all connections are secure.
HELP..........!!
HELP..........!!
RE: Idling problems
checked for air leaks. swapped the MAF with my UR quattro one (RS2 spec) and no change. New plugs fitted but no change. Interestingly the car idles absolutely fine with the MAF disconnected (but obviously will not drive under boost in this guise!). Any ideas?alastairg wrote:Air leak
MAF dirty or done
Sparks
1995 (M) Noggie RS2. MD357 turbo and remap. tba bhp.
2000 (X) Noggie RS4. Miltek Cat back. No cats. B7 discs/RS6 calipers. ally flywheel, DUH FMIC, ceramic coated tubular manilfolds, large intake pipes, RS6 turbos, 3" downpipea, large injectors etc MRC remap, 592bhp, 535lbft
1990 (Q) 20vURQuattro. Being fitted with RS4 motor & 6 speeder,porsche brakes.
RE: Idling problems
Did you check altitude ambient presure F96 sensor
Green 95 RS2 TT(twin torsen) Mihnea chip, full 3" custom exhaust, forge dump valve, 18x8 boxterS, Rose joints top mounts, alloy sub frame, powerflex bushes,Bilstein,Neuspeed 19mmRS4 rear ARB, rear V8 Torsen, Removed (AC,Aux Rad,spare wheel and tools)
RE: Idling problems
No I didn't...! What is it, where is it and how do I check it!maRS2 wrote:Did you check altitude ambient presure F96 sensor
RE: Idling problems
Have a look at this thread on the S2 Forum:
http://www.s2forum.com/forum/showthread.php?t=2899
Glyn
Navarra Blue RS6 Vorsprung (C8)
Sepang Blue RS6 Performance (C7) - sold
Sepang Blue S5 sportback (B8.5)- sold
Monza Silver RS6 (C6) - sold
Sprint Blue RS4 (B7) - sold
Polar Silver RS2 (B4) - sold
Which dump valve did you use?
I replaced mine with a Forge 007. Others have used the S3 one or of course you can always stick with the OE RS2 one.
Glyn
It was a piston type one and was leaking under a vacuun test. I replaced it with the S3 item which by all accounts is stronger than the OE RS2 one..?
