porsche 911 alloys on RS2
Does anyone know if the porsche 911 wheels of 8 x 18 size with 5 stud on a 130 pcd with an ET of 52 will fit an RS2 without mods or spacers?!!! (See attached picture)
- Attachments
- 5b_2.jpg (6.78 KiB) Viewed 1308 times
IIRC The bore diameter is different between the Porsche rims and the RS2. I'll see if I can dig out the numbers unless someone beats me to it.
The ET should be fine and I run 8x18 on my S2 avant (identical suspension and bodywork to RS2) but had to play around with spacers when I was fitting the 255/35 rubber. If you stick to a 225/40 you should be OK.
1995 S2 Avant with a few mods
